  • Replies 60
It almost certainly won't be on because the weather is just too unpredictable.
As I said to Paul on the phone this arvo if their is 1 shower in the morning then nothing it will be on but if its rain/clear/rain/clear on and off all morning don't even bother.
yea :D dammit..
Yes it's off.
I've spent 2.5hrs working on my other car already so it hasn't been a total waste of a day.
ive put some new chrome door handles on the baby's room door and hung a shutter blind on the window. Now for the downlights!
It was off.... i went, and it was closed. called the number, and an answer message said it was cancelled due to crap weather..!!
Glad i went to Initial Drift first tho, that was ok, rain made it a little unpredictable though.
Aaaaaanyway, had a beer in bar near, then on to home, stopped at restruant for food. all-in-all, not a bad day considering damn weather.
Oh, and while there, i stopped someones dish-rag dog gettin squished on the aproach road, only to see it gettting some grief from a few Magpies in the grounds....
Pffttt to the weather.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
