RB25DET S1 with a GT35R
With N1 oil pump, eagle rods and CP pistons whats a fairly safe rev limit on the stock head?
Also if I run the Tomei poncam's with that turbo, what are my realistic gains? who would it effect my red line on the stock valve springs? or is it worth at that stage going with a slightly stiffer set?
I need to get about 8500rpm out of the engine in 2nd and 3rd to make best use of the local track,
Thanks
https://www.sau.com.au/forums/topic/183612-rb25det-cams-and-red-line/
8500 is too much for a stock head.
You'll be getting valve float etc.
I ran 8000rpm as limit in my stock head and it was ok. But some people have had issues even with that.
So going another 500 isnt going to see things last too long i would imagine
My whole motor has 15 000km's on it, so hopefully my guides ectr are still mint, with a set of poncams and springs fitted, at what sort of RPM can I expect the lifters to let me down?
It will only be needing to go over 8000rpm for maybe 1 or 2 seconds at a time, not very often at that.
What cams and springs are you using? also what turbo?
Im just running out of gear coming into 2 corners at my local track, and a few hundred extra RPM would go a long way, currently a stock RB25 s1 with a GT3076R and loads of supporting mods running 1.4bar, going to be building the motor at the end of the year so trying to get all the parts planned out and on my shelf by then.
My car is not a track car, its an everyday car which i use maybe once a month at the local drag strip or race track,
Currently making 352kw at 1.3bar with:
Stock internaled RB
Greddy intake mani
76mm charge pipes
GT3076R
Tial 38mm gate
PFC
740cc
Meth injection
and the other usual things like pump, ectr,
To be done end of year:
8.5-1 forgies
eagle rods
ARP head studs
ACL race bearings and gaskets
tomei oil restrictor
external oil return
N1 pumps
pump collar
ectr,
Only thing I havent worked out is a good street reliable head combo, I definatly want to go with the poncams for a nice easy to drive setup, but not sure what other tried and tested parts you guys use with the hydro lifters.
Why not change the diff ratio?
Whilst you won't be accelerating AS quick, you won't be running out of puff either.
On the standard cam, I personally don't find all that much power above 6500 compared to if I upshift at 6500RPM.
You need to remember, when you put your power through the different gear ratios, you get a set amount of torque at the rear wheels, and alot of the time (Nearly all the time in stock cams) it's more beneficial to shift a few hundred RPM before the standard redline to get maximum acceleration...
Wheel dyno,
It is a .82 with the 4bolt GT outlet, I run quite a bit of timing to, meth works quite well for that,
http://www.rezlo.com/Pages/silvia.htm that was it a few months ago before the new intake and charge pipes, last video clip is of the current setup, Just had a drag event on sunday, trapping at 209kph at a rather slow 12flat due to some traction issues im working on,
Edited by Rezlo
129.8mph.. I'd say the power is definitely up there. No doubts here.
I also run a Gt3076 .8; looking at water meth in the near future.
Top work.
Thanks, I try to keep it looking as clean as I can.
GT3076R seems to work well with the RB25, but the meth inj made one of the best improvments to my car, I use a devils own progressive kit with #15 nozzel running a 50/50mix, Ive been up to 1.5bar on the streets with 95pump fuel with zero detonation, though only for short bursts as I want to keep the motor together till its time for the build.
Any Idea what the poncams will do spool up and top end wise with my setup? Ill probably go with the tomei springs at the same time, just worried about the added spring presure on the hydro lifters at higher RPM.
Anything else anyone can coment on internal wise ontop of my list above?
Edited by Rezlo
The cams will help hold top end up for longer and improve spool slightly; as you have a short runner plenum this with the cams will allow power to peak a little later as result making a little more peak and possibly improving that TS down the 1/4. :whistling:
Go the springs and cams. The springs won't cause issues with the hyd. lifters.
A set-up that has the potential to do very well.
With your build up consider a series2 crank or a jun style crank collar so you don't go breaking oil pumps. ;)
Head oil restrictors - 1.5mm up front, blocked off rear as per sydneykids recommendation works VERY well.
How hard do you currently rev it? Where does power peak?
Ive got a jun pump drive ready for install, I also have a tomei oil restrictor ready for the rebuild,
Ive currently got my shift light coming on at 7k, shifting at 7200 to 7500 some times 7700 if i dont catch it in time, set the redline up to 8200 so I dont touch it (not a fan of fuel cut at full boost)
At the moment it pulls pretty linear from 6000 up to 7500, I dont feel much drop off at all, If I shift under 6500 it knocks the wind out of it, usualy pretty badly.
My peeve with the setup is that its a touch violent coming into boost, I want to smooth it out especialy in 1st and 2nd to help with traction, and being able to run it up to 8000rpm in 1st and 2nd would help quite a bit, as our tracks arnt that great and you have to work at keeping it tractible even with 275 wide M/T's.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
