so skyline's are the new VL turb's now?
Weren't they always?
I wish all you dosing (fully sick) skyline owners would sell up and go back to Homodores.
Sick of all this bullshit modification for the sake of a stupid sound which impresses very few people anyway!
Save your time and money on actually modifying for a performance gain perhaps.......aahhh whatever each to their own.
Flame away my dosing freinds.
Jeez ease up, like you said each to their own.
I dont know why some of you guys are so against dose/flutter. I dont think I have met anyone who doesn't turn there head when they hear a dose/flutter?
It sounds good, and there is nothing wrong with it. Doesn't even compare to the poofy sound that a BOV makes.
I'm not trying to start a dose/flutter/bov debate, but if he wants to make it dose, let him.
All he asked was, is it ok to put the AFM into the cooler piping, not "hey, how can I make my skyline dose!?"
Edited by abu
i done this only for the reason this to my car was to eliminate the 4 inch inlet of the turbo being reduced to like 2 1/2" from the afm so i put it on the pressure side of the piping so i can have 4 inh all the way to the turbo inlet
f*#k the dose i try my hardest to get rid of it if you want a dose get a vl
muzza'z lol
the restriction is the other way around
what size is the pipe work after the compressor outlet ?
oh, and btw, what the hell is "dose"?
dose/flutter = compressor surge?
shhhhhhhhhhhhhhhhh (spool up)
ttttttuuuuuuuuuutttttuuuuuuuuuttttuuuuuuuuuuuttttttuuuuuuutuuu!!!!.. (compressor surge - backing off throttle)
:thumbsup:
Edited by abu
paul i think you have this one wrong
my intercooler piping is two and a half inch all the way thru all the way to the plenum and the afm is around 60 cm before plenum after the intercooler piping
the inlet on the turbo is 4 inch so to put the afm in front of that would limit the air flow into the turbo
i have a power fc to tune the lil gritty bits
ha ha i must be too old for that fully sick lingo. why not call it compressor surge as that is what it is?
also, in regards to the comment that "I dont think I have met anyone who doesn't turn there head when they hear a dose/flutter?", then you obviously haven't spoken to ANYONE why doesn't own a skyline or performance vehicle. most people hate it. in fact, i even hate it. i think it sounds stupid and wanky and when i hear it i cringe and vomit a little bit in my mouth
also to make it does have no bov then she will does also use stainless steel longer the better with a 90 bend in it
LOL
But your from Brisbane, I think maybe thats way. No one up QLD way doesn't seem to know what dose is, not having a go!
I haven't met anyone from VICTORIA then, that doesn't turn they head when they hear it.
This is way off topic haha.
Yep.
I was just saying ist off topic to what he was asking.
I have found a 45 deg, 2.5" to a 3" pipe doses best. Not to long though.. my personal opinion since where on the dose topic.
Edited by abu
LOL
i am a victorian who recently moved to brisbane, so there goes your theory!
Edited by WazR32GTSt
Damn! lol
How old are you if you dont mind me asking?
Might have to put you in the "mature" category since you don’t meet the minimal requirements of the QLD one.
Edited by abu
i htink this idea is flawless at best without an ECU tune of some sort to compensate for the new AFM location
my understanding of hte AFM is this..
the AFM works by calculating. it does not directly measure airflow.
it has a wire that hangs into the lumen of the pipe. this wire heats up to a certain temperature that correlates with a certain resistance in the AFM (contains a variable resistor). when ambient air flows over that wire, it cools the wire down. the more air that flows over the wire, the more it cools the wire down. thus, as airflow increases the wire cools down more and the resistance in the AFM changes. this correlates with a change in voltage to the ECU.
this way, the ECU knows approximately what the airflow is based on the hot wire's operation.
now i see 2 major flaws with placing the AFM in the cooler piping
1) the air is compressed. there is absolutely no evicence that i've ever seen that says that compressed air will cool the wire at the same rate as air at atmospheric pressure. let's look at it from the particle model. say i have 100 particles of O2 in a fixed space and it cools the hot wire by 0.1degC. well if this is compressed to 1bar i now have 200 particles in that fixed space. who's to say that this compressed air will cool the wire by 0.2degC? i don't think the relationship will be as linear as you might think.
2) the air is hot. that's right, its after the turbo. that means that the air going over the wire could be up to 50-80degC having just come out of hte turbo. i don't think hot air will be able to extract heat from the wire as would ambient air, and if it does then it wouldn't be at the same rate as ambient air that passes over the AFM normally.
--> but, i believe that both these issues could be compensated for by a good tuner
so, in summary... my understanding is:
1) the AFM works on a hot wire principal
2) placing it after the AFM means that it measures compressed air not normal air, thus it will not measure effectively without a re-tune
3) placing it after the AFM means that it measures hotter air rather than ambient air, thus it will not measure effectively without a re-tune
this is only based on my understanding of how the AFM works and my understanding of basic physics/chemistry. it might help or it might not, but i thought i would throw it in for discussion
cheers,
Warren
This has been spoken of many times on this and other Nissan forums. I can never stay away from commenting :thumbsup: I almost had the NRG to getup and try it, might in the future.
Hotter Air: Common debate, though can you guesstimate the temp of the air going through the AFMs in a stock setup, when car is stand still and its 40 outside? I would guesstimate close to 50-80
Compressed Air: Its the same amount of air, its just moving faster now (pressurized) I believe it would have close to the same ability to absorb heat from the hotwire, as its denser.
I would say, with a re tune it should be fine, only issue being oil from stock recirc setup, or from leaking turbo cartridge.
turbocharged air is going to be way hotter than intake air.
if intake air is 50deg (because you have a pod in an engine bay) then figure after the turbo its going to be higher, even if its only 80deg, its still higher
in regards to pressuresed air, yes it will move faster, but you are overlooking the fact that pressureised air means that there is more particles of air in a given fixed volume. althought it is moving faster, how do you know that it is cooling twice as much? how do you know that its is cooling proportional to normal air? saying its "close" isn't good enough i believe
its just not as simple as it seems in terms of the physics of it all
now an ECU tune changes the game altogether and its great because the tunes doesn't have to know the slightest of any physics of it all, they simply have to look at the exhaust AFRs and adjust the mixture accordingly..
Damn! lol
only 24, but given the fully sick crowd of skyline owners these days is 16-20 i consider myself old for the skyline community..!
pfffft.. your still young. I'm 20 my self.
Some people on these forums in there 20s act like there in their 40s.
Edited by abu
the point paul is making is that the piping after the turbo is only 2.5" so having the afm before the turbo isn't really going to add that much restriction. and unless your compressor wheel is actually 4" then there is no real gains had by having a 4" pipe. and i don't know of any pod filters with a 4" outlet, so wouldn't you just have to have it reduce back to 3" anyway, which is the same size as the afm.
also if you were to run this setup with a bov you would have massive stalling issues, whether it is atmo or plumback. with a plumback and the afm in the stock location it doesn't really register any air moving through it when you lift off. with it in the cooler piping when you lift off and the bov opens it would be registering all the air in the cooler piping that is going past it out the bov and dump a heap of fuel in. so you would need the afm right near the throttle body, and have the bov closer to the intercooler than the afm.
why doesn't the idiot just block off the BOV ?
Oh, I know why, I bet he has a massive f**ken Trumpet amplified supersonic twisty whirly spinner shiney chrome space ship vent to atmosphere one, because he thinks all of the women he makes it go off in front of a all going to get really wet, and come running and try and get into his car?
Another f**king idiot to make cops hate skylines more. Great.
Guest
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
