Hey,
just installed a FMIC on my 32 and was wondering about the reo bar i was told by everyone that i knew that i had to cut the bar but when i installed it the bar fitted on perfectly in front of it not sure why maybe my reo bar is smaller than most not sure??
anyone else not had to cut the bar??? im a little concerned that i might have not installed it correctly
Cheers
Matt
https://www.sau.com.au/forums/topic/183831-horray-finally-have-intercooler/
If you install it correctly, then you don't need to cut the reo bar. Its illegal to cut it as it provides reinforcement. A lot of people rush the job and cut their reo instead of working slowly and putting it in right :whistling:
yeah okay i went into my mates work to do it he works at centre ford in the city so we had it up on the hoist :blink: and all the air tools it only took us about 3 hours to install the cooler but another hour to cut the front bar and refit it did a good job though i think
i see on some cars that the reo bar is covering a bit of the top of the core of the intercooler, wouldnt you want as much air going through?? but then again the bumper doesnt have much of a hole for the cooler but if you go aftermarket front bumper such as do luck i think the reo bar would need cutting.
I spent hours messing around trying to avoid cutting the reo, I couldn't find anyway it would fit without cutting it, didn't have to cut much though. The same was done trying to avoid cutting the fan blades but if you lifted the pipe up so that it would clear it would touch the lining on the bonnet. I ended up cutting a square hole to give me a bit more movement so that i could try to make it clear the fan blades but no help.
I was fitting the cooler to my car which is a r33 s1 and at the same time one on my friends r33 s2, i noticed the reo bar was smaller on the s2, but still required cutting.
-michael
hey guys!
talking about intercooler, i was wondering....
i have heard tat putting a bigger intercooler wit out increasing ur boost will cos lag.
current mods are 3" straight thru exhaust wit bigger front n dump pipe + air intake.
stock boost.
any harm to the engine / long term/ short term?
thanks for all the info guys!
hey guys!
stock boost.
no harm to the engine it fine just do it
also theres no way around putting a fmic on without cutting the bar soo f**k knows how you did it
hehe in that case if there is anyone who wants me to install their front mount without cutting their reo bar $200 each you supply pipes and cooler :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: just jokes dunno how i did it ;)
it was a bit annoying though having to cut my front bumper but just managed to score a GTR front bar for $150 so im pretty happy bout that :)
Mine is one of the just jap coolers type 2 and i have a 1989 r32 so it couldn't be because of the year.
Actually i had a prang about a year ago wrote off the front end(wasn't my fault some chick pulled out in front of me in an x-trail) i went to the an auto wreckers in midland and got a nose cut so maybe that was a later model cut??? maybe 92 model
erm.
i got a hks types fmic for the gtt and do i need to take our the reo bar?
need any custom work?
or direct bolt on?
you will need to cut a 3 inch hole (depending on the size of your piping) just under the battery for the return pipe not sure how the hks kit fits though never done one of them but i assume that they would be the same as mine depending on what size it is.
You should allow yourself about 4 or 5 hours to do it though
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
