I've realised that my licence has lapsed, and I am due to attend a track day on Saturday. The licence renewal/application for states that a 30 Day temporary licence can be obtained through the CAMS endorsed club, but it's not applicable for renewals (new applicants only!)!
See the bottom of the application form here: http://www.cams.com.au/downloads/paperform...Application.pdf
I'm certain that my new licence wont arrive before Saturday, so what can I do? Any ideas?
https://www.sau.com.au/forums/topic/183848-cams-l2s-renewal/
This has happened to me aswel Jon
Easy fix - ring CAMS and be as nice as you can, then explain the situation (first time renewing etc) and apologise, then ask if they can please tell you your licence number or even fax a quick coversheet to you saying that, then take that to the trackday
Its worked for me in the past :whistling:
Hey mate,
If you have infact renewed your licence.... not really sure from your post, you can get cams to fax through an authority form which you take with your old licence and show the officials and that will be fine to get you on the track!!!!
Thanks sanger.
I called cams this morning and explained the situation. The guy said "Just make a note on the application that you will be requiring a temporary licence, and provide a fax number for the licence to be faxed to."
Sweet! - Thanks for you help guys!
It turned up on my fax machine only an hour or so after I faxed the application form to them! :D
I was planning on having to annoy them about getting the temp licence to me, but I was pleasantly surprised!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
