  • Replies 57
Brant Website
The top of the line is the Nemesis. It's a 6 point immobiliser with alarm and a few extras (some you must pay for). Most people i know with a Brant have had very little problem with it.
I've spoken to brant they are very helpful. Anyway the more people who commit the bigger the discount. Brant already give all Silvia NSW members a discount.
BUT one thing i found is that the 6points of immobilisation it hink only imobilise 3 components. The starter motor, electronics and fuel pump. There are just 2 relays per component. Although I'm not sure about this, this is something that I've been told by many automotive electricians.
https://www.sau.com.au/forums/topic/1840-brant/#findComment-34725
yeah thats correct the other 3 points comes from the keypad...
Basically the same alarm system as the ones on the new sti/wrx minus the anti-car jacking feature and uglier keypad.... tried to get the installer to install the car jacking feature on mine but refused due to politics with Subaru.....
the only problem i have with it is the range isn't that great.....
https://www.sau.com.au/forums/topic/1840-brant/#findComment-34751
I already got a brant system, its the aa02 tho so its not not the top of the range.
When i had one of the brant guys 2 come over & fix my alarm, he said that i can just upgrade to the Nemesis by getting the missing parts like the keypad etc, & it wouldnt cost 2 much also.
If you guys do decide 2 do a droup buy, please ask about ppl who already have a brant product & wants 2 upgrade to the Nemisis.
Thanks,
Joe.
https://www.sau.com.au/forums/topic/1840-brant/#findComment-34774
Originally posted by PranK
mine all up was $1400ish... but that is including everything!! 4 sirens, several different sensors, remote window up, keypad etc..
hahah can anyone say overkill?? hahaha :)
gusy i dont knwo about u.. but alarms are soo ****en easy to bypass weather u got a 1400 one or a 300 dollar one... ask any one who installs em and he will tell u that it will take him hte same time to disable both of them if he wanted too..
i did a bit of research when i was getting mine... adn i couldnt believe how easy the things were to crack.. 2-3 mins and the alarm is disabled.. ure best solution i think would be to do a custom install.. diff coulour wires.. position of main control box in weird places..stuff like that is ure best solution
https://www.sau.com.au/forums/topic/1840-brant/#findComment-35167
hey guys check this from the brant website
BRANT does not discount - our prices are fair and reflect the cost of experienced trained labour, tried and tested quality products and ongoing after sales service. Normally to discount means cutting corners and offering a little less than we are comfortable with. Our company is built on reputation, word of mouth recommendations and hard earned support from leading insurers and car importers"
i dun think they offer group discounts do they?
and you guys who fitted the AA02...
how much did it cost all up?
mc
:shake:
https://www.sau.com.au/forums/topic/1840-brant/#findComment-35187
Travel time costs us money - if you can arrange two or more vehicles to be fitted with Brant systems on the same day at the same location we are happy to pass the savings on to you by way of an attractive 'multi car' discount. The cars can be your friends, relatives etc - the more cars you book on this basis, the bigger the discount! Talk to us about how much you can save this way.
https://www.sau.com.au/forums/topic/1840-brant/#findComment-35248
Any alarm can be by-passed. Just like any computer can be hacked.
But not having one will make things easier for the theives to knock the car off. Sometimes a few seconds can make the difference in someone getting away with the car, and them getting caught red handed.
https://www.sau.com.au/forums/topic/1840-brant/#findComment-35278
Guest DFLASH
not sure whether this would work, but...
say you had a S-AFC and disconnected it when your car was parked, is it right to say that the car will not start without the unit?
I know for a fact that the car won't start cause my S-AFC was faulty with the throttle signal and the car wouldn't start.. so if i disconnected the unit.. then I think the car wouldn't start, but they'd have to rewire the ECU and air flow meter signal..
just a thought..
https://www.sau.com.au/forums/topic/1840-brant/#findComment-35346
Originally posted by | hype^ |
PRANK -  does your alarm have romote engine start or a remote sorta like the boomerang one?
i recon thats the best idea that way you can get to ur car b4 the theif has a chance to disable it,.. coz theyll be able to disable it no matter what..
this wouldn't work because i have a keypad to start the car..
URMINE, it can be bypassed of course, but it would take them a little while to do it. :(
https://www.sau.com.au/forums/topic/1840-brant/#findComment-35515
Brant do give group discounts. If you get the nemesis base model (no extras) its around $1100 retail. If you have two cars it comes down abuot $150 per car. Don't quote me on this cos this is what i was offered a month ago.
The AA02 is already cheaper so a big discount may not be offered HOWEVER, if you buy the AA02 through Autospeed its cheaper than the retail at Brant. AND Brant technicians come to install it anyway. This is what a friend did.
Yes all alarms can be bypassed by they are still deterrants.
https://www.sau.com.au/forums/topic/1840-brant/#findComment-35525
christian.. ure keypad ull find is only a "gadget" feature. the key pad should be connected to a control box.. all u do is bypass the control box and any imobiliser/keypad will cease to exist.. litterly less than a 1 minute reconnectioin on a STANDARD installatioin..
im sorry man ure brant will most prob be as easy to bypass as my 350 buck job :(.. mine might even be a bit harder as when i did the installion i hid a couple of wires and a certain control box :(..
https://www.sau.com.au/forums/topic/1840-brant/#findComment-35532
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
