This question goes out to all the R32 GTS-T owners on this Forum.
What is your best 0-100km/h time?
My R32 is pretty much stock as a rock apart from:
- Apexi Pod Filter
- GKTech 3" Stainless Exhaust (Split Dump Pipe)
- TurboTech Boost Controller (Boosted to 13psi for my run)
The best I managed to do in 3 runs was 7.4 seconds, and that was with alot of wheel spin :laughing-smiley-014: . I have read that a new stock R32 GTS-T should be able to do 0-100km/h in 6.9seconds, although this would be brand new and under perfect conditions. My manual skills are not fully developed at this stage as I have only just become a Skyline owner. :)
I am interested in the times that other R32 GTS-T owners have been able to manage, and with what mods? To those who complain about measuring 0-100km/h times: Any speed over 100km/h is impractical for street use ;)
https://www.sau.com.au/forums/topic/184212-0-100kmh-times-r32-gts-t/
Crap man that is pretty shocking,
I got a 6.5 without trying in my old R32 GTS-t, auto too :S
with crap rubber on the front, average rubber on the rear, 3" rage exhaust(no cat), repco pod filter(crap) and a chipped ECU, everything else was standard
I just slapped it in from N - D about 5000rpm(yeah i know bad for the driveline, oh well)
I'll test out my manual GTS-t pretty soon, just waiting on getting it running, I was using a G-tech Pro R on the runs, it's an excellent device, what are you using?
I'm using a GTech Performance Meter/Pro. I think its a cheapy but it does the job.
Yea, I definitely need more practice, this is my first time driving a manual. What would be an ideal RPM to launch at? The best time I could achieve was when launching at 3,000RPM, but I seem to get too much wheel spin.
haha those gtech units are nifty as. Purchased one not too long ago from ebay for a couple of dollars.
Havent done a 0-100km test yet as clutch slipping + bad axle tramp.
Once clutch is put in ill give it a test then :)
The gtech's are quite accurate. Placed it into my friends car at drag strip. It was half a second off from the actual qrt mile. Was impressed by its accuracy.
it read half a second more. So the gtech was reading slower than the actual drag run. Over-estimated instead of under-estimated.
Cant expect better results for a $50 timing device :)
Hahaha. I wonder about mine aswell. During my 0-100km/h runs, the G-Tech seems to reach 100km/h before my Speedo. So either the accelerometers in the G-Tech are more accurate than my Speedo (possible), or it is the other way around :thumbsup: .
So far I am the slowest R32 on here. We need more 0-100km/h times people :down:
yeah I love my G-Tech :( picked it up 2 years ago for $200NZ, the pro model and can be logged into my computer for datalogging and laptimes :spank: it's great
picks up drag times down the split second,
as for the reaching 100k faster than the speedo, yeah mine does that on my old car, on my newer one it reaches 100k after :S
Probably the good old nissan factory error in their speedo, i think its +- round 5km or so
Also tried it out on my partners corolla :D 0-100 in 9 seconds :S she'd kill me if she saw her hard I was revving the old granny mobile
Also tried it out on my partners corolla :spank: 0-100 in 9 seconds :S she'd kill me if she saw her hard I was revving the old granny mobile
Nice. I got my old auto 4cyl 1990 Magna TP down from stock 14seconds to 10seconds after basic stage 1 mods. Makes me feel disappointed with my R32 time :(.
Stock minus catback, 6k launch 6.3 sec. also with a g-tech.. Not GTS-t.. a GTS-4 ...
6K Launch? Holy Crap, how did you control the wheel spin? :laughing-smiley-014:
There's your answer :D he's got a GTS4 :wave: they launch very nicely, although not quite as good as a GTR
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
