hi guys,
i have an r33 gtst with turbo back zorst,550cc injectors,z32 AFM,bigger fuel pump,apexi power fc,and EBC.and now i am looking toget a better turbo...i am wanting to get to about the 230/240rwkw mark....what is the best turbo to reach these power leavel on a bit of a budget?? and has anyone used a GREDDY TD-05(as i can get 1 brand new 4 $1100) to get that type of power and if so are they very good??
Thanks heaps.
https://www.sau.com.au/forums/topic/184292-what-turbo/
what just a standered r33 turbo that has been highflowed?
Yep high flows can run some good power.
Take a look through this link below, its got dyno results for RB25's with turbo upgrades and supporting mods.
http://www.skylinesaustralia.com/forums/in...showtopic=55845
https://www.sau.com.au/forums/topic/184292-what-turbo/#findComment-3336570
If you want about 240rwkw a HKS2535 would be pretty good, there is a few RB25s running them.
Otherwise if you don't want to spend that much just grab a RB25 high flow, that will take you to 240rwkw.
Edited by abu
https://www.sau.com.au/forums/topic/184292-what-turbo/#findComment-3336574
gtrs or highflow
lots orf proven results
no guesswork required
What guess work is there with a Trust turbo? Get off the bandwagon man, admittedly TD05 is a POS from what I've seen on a couple RB20, but you can hardly call it unproven seeing it has been bench tested by a tuner just as reputable as HKS.
EDIT: I should clear the above up. The evil and dark brand of turbos known as Trust should not be ruled out.
Perhaps consider the TD06 25G kit for the RB25. The pro style kit has every bolt, pipe, silicon line, washer etc you can think of. GTRS does not. But horses for courses. If you wanna chase 300rwkw a T67 could be swapped later onto a trust kit, or a larger rear housing onto the TD06 (although I think it comes with 12cm already)
Peace.
Edited by Wheezy
https://www.sau.com.au/forums/topic/184292-what-turbo/#findComment-3336653
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
