Now it's my turn to be off the road!!!!
Yesterday just as I was on the way to shoot a wedding the R30 just stops. It looks like the Dang F#%^ing fuel pump sh!t itself, right on one of the busiest roundabouts on the Central Coast. No bastard would help push her off the road but plenty had advice what to do with her. Luckily the Bride lived nearby and sent the limo to rescue me whilst the POS spent the night on the median strip.
I've got her home today but it's pissing with rain so I have not been able to get under her to check it out. Called Repco to see what a new pump would cost but the only one they have listed is a "high pressure" replacement for $700+ (WTF).
Does any one know if the pump is serviceable or a sealed unit? Am I going to struggle to get a new one or should I head to the wreckers ASAP?
Thanks
Wardie
Edited by wardie
https://www.sau.com.au/forums/topic/184293-r30-fuel-pump-question/
i know they are pretty easy to replace, as they arent in the tank itself. they are underneath the car above the right cv shaft area.
one from the wreckers could be a quick fix, but keep an eye out for a bosch 040 or similar.
$700 is the most fkn useless qoute to get from repco... fk heads!
even pumps from RB30s are meant to be able to fut... i will find out soon enough!
the r30 pump is external and the r31 pump in internal..
most aftermarket places can get you a good external fuel pump, 500hp+ rated ones, for around $3-400, then any EFI place could put it in for an hours work ($70-90).
$700 just for an r30 pump, thats no incentive to go original
if you don't want a good aftermarket pump now go to a wrecker and get a stocko $50???
The only trouble I ever experienced with my RMR30 at first glance seemed to be the fuel pump, but oncloser inspection was the pressure relief valve.
Malfunction of thePRV caused the pump to malfunction. Check the valve operation
Got some quotes for a standard fuel pump today, they vary from $280 up to $395.
The one Repco quoted me on was a High Output unit.
I'm off to the wreckers tomorrow to see what I can get. Any one know if any other Nissan/Datsun models have the same unit or compatible?
66yostagea - when I turn the key I can hear the fuel pump relay clicking in but the pump does not run
Wardie
Wardie
I got a couple of pumps here at home. One is from an L24 and one from a rb30et. The L24 one is pretty new, i changed it a couple years back but removed it for a larger pump. Let me know if you want either one.
Thanks for the offer skybt1 but I got to get her on the road by Wed so I'll be off to the wreckers early tomorrow.
So I should look for a VL Commie pump as well. Are they cheaper new? Anything that is Nissan and Skyline seems to attract a premium price from everyone.
Wardie
This guy has the standard vl pump (non genuine) for $105 or genuine for $145, but if you need it by wednesday you may be out of luck, unless you need it FOR wednesday then if it gets expressed tomorrow you should see it in time.
Back on the road!!!
2nd hand pump from a R30 sedan $70 but I managed to get thrown in for nix 2 x idler pulleys for the A/C and Power steering belts, 1 x washer pump and best of all a complete set of original skyline wheel centre covers in good condition (quoted at $50 last time I was there).
I'm happy again!
Wardie
  • 2 months later...
Matty T: do you have any pics of your R30 rally car??? Very interested to see what you've done.
Packy, I really should put something together, detailing the specs. Probably best for it's own thread.
There's a couple of recent photos on flickr: here and here.
Wardie
I replaced my fuel pump on my R30 when it died without notice with one from a VL. It was easy to get & I think cost around $300
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
