i think ill give it a shot, my rear bar is already off the car and my cousin got a GTST. i have to do it because the standard exhaust doesnt let the aftermarket rear bar i have go on properly!!
thanks for ur replies anyhow
ok, here's another question
These fully sick criminals, like so professional u just wouldnt believe, when they stole my aftermarket gearknob, decided to take the gear boot and surrounding the boot is attached to that clips onto the console. NOW does an R32 GTST one fit? Cause im having a bit of trouble finding a GTR one. If anyone has one they dont need,dont be shy....
Not to sound like an ass, but why wouldn't a GTS-T one fit a GTR? I understand why you weren't sure on the rear bar, but the gear boot?
I'm going to take a guess and say that they're the same because I never knew there was a difference.
Sorry if this post didn't help you in any way ;)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
