ive got a r32 gtst and i just recently noticed my car smelling like radiator fluid.
i checkd under the glove box near the firewall and found a some radiator fluid(very little of it)
imnot sure where its leaking from.
has anyone had this problem before?
https://www.sau.com.au/forums/topic/184420-radiator-fluid-inside-firewall/
yep, leaking heater core, or possibly the hoses going to the heater core. either way it wont get better, only get worse until one day it dumps all of your coolant into your car which will wreck half your carpet and stink the car out for a long, long time. unfortunately it's not easy to fix. removing the heater core means removing nearly all of the dash :D very time consuming if you do it yourself and very expensive if you take it somewhere.
It sounds like your heater core is stuffed or your hoses have come off. Summer's coming up so there's no need for the heater. Just unplug the hose that goes to your heater from the engine bay.
You can get a second hand heater core from your local wrecker, but you never know, it could be stuffed too.
The heater core is located at the back of the dash. You're going to need to take out the whole dash as far as I know.
sounds like you have no idea what your doing
get some one to help you or take it some where that knows what they are doing
last thing u want is to get an air lock in the cooling system and pop a head gasket
I would definately buy a NEW core. there is so much time in swapping them over get a new one. Places like natrad, adrad etc will be able to give you a core of the right shape and size. from memory they are not expensive, maybe $100-$150.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
