77 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
hey guys!
for the past year and a half me and my mates have been having a disagreement
about the width of our tyres. my view was wider (265) tyres are better as there is more
serface area on the road to get better traction.
his opinion is that skinnier (185) tyres have more pressure on the road,
therefor the traction and handeling is better.
what are your thoughts???
Edited by SHY_33
https://www.sau.com.au/forums/topic/184439-skinny-or-fat-tyres/
  • Replies 42
Your mate is partially correct in places of limited traction like wet roads where a skinnier tyre will "cut" through the water to gain traction. A wider tyre will tend to sit on the water.
This is similar concept to when (in a wheels article) heavier cars out braked lighter cars in the wet. The greater weight on a smaller surface area assisted in traction.
On the whole he is wrong and the "stickyness" of the tyre has a lot more to do with it.
well the way i look at it is the v8 super cars dont put 185s when it starts rainig hey so fatter is still betta
i would say that is because skinny tyres are better only to a certain point, ie: if you put bike tyres on it will obviously not grip, but if you put 305s on with will aquaplane real bad, they must have found a happy medium with whatever they use
So far so good 1nce i get enough people and a few pages im gonna print it off and give this forum page's to him,
his a very close mate but he still shits me with the skinny tyres are betta, and yes he had 185 on his car now has 225 and wont say anything about the handaling of his car special cause its a vc comordor,
but whats funny it doesnt stop there we are into extreme 4wd and he has started it again likes of i had a patrol with 39.5x16x15 and he had 35x10x16 and he still says the same fact skinny is betta.
EVERY PLEASE VOTE
thanks john
Well everyone is wrong so far. It depends on the application and the car.
Why would wider tyres neccesarily make a car have more grip? Chances are with your hetik skyline with 10 inch wide rims that weigh 30 kg a corner cos you got them at wheel worx aren't going to give you more grip now are they?
So maybe in outright grip in a straight line having a wider tyre will be usefull, but would you rather have a 100 dollars 285 wide tyre or a pirelli 225? i think i know which i'd prefer. And when it comes to corners i'd say suspension plays a greater role in traction relative to how wide your tyres are.
So to conclude read and find whats the best match for your car.
It's just like getting a 200 intercooler off here or getting a 1000 dollar greddy or arc cooler. Sure the 200 dollar may be bigger but i'd bet the farm the arc would flow better and cool better.
You pay for quality full stop. but now i'm getting off topic.
arhhhh
Edited by kralster
arhhhh
are u taking wind resistant into them calculations , i think the question is in general do wider tyres have more grip than skinny tyres not do 225 goodyears on a supra have more grip than 235 falkens on a ford at 34.6759657842 degrees
lol @ ^
lets face it, the broad answer to this broad question is - wider is better.
your getting too technical.
think of it this way. these two guys had a few beers, watching ralph tv, maybe some cones, and then 1 says skinny tires are better than wide.
what do you do?
*SLAP* i'm rick james bitch
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
