Reading from the top:
System On/Off: Button I
Door lock/unlock: Button I
Boot open (option): Button III hold for 1 sec
Panic mode on/off:Button I, hold for 3 sec
I think this one is to check where you parked it:Hold button IV, once it's beeped twice it should read CDOFRm
Beep on/off:Hold button IV, 1 beep and it should read CODFRm, 2 beeps and it should read CHIRP
Melody sound on/off:Hold button IV, 3 beeps and it should read SOUNd
Shock sensor cut:Hold button, 6 beeps and it should read LPG
Back light:Button IV
Clock set:Push buttons II and III simultaneously, 2 beeps and it should read CLOCK, II adjusts hours, III minutes
Wake up alarm:Push buttons II and III simultaneously, 3 beeps and it should read CLOCK, II adjusts hours, III minutes
Engine start timer:Push buttons II and III simultaneously, 4 beeps and it should read CLOCK, II adjusts hours, III minutes
Remote engine starter settings:Button II, hold for 2 sec, it should chirp 3 times
Hope that helps a little
Edited by dodgybrooks
Thank you very much...
I might have some other stuff that needs translating too because I ended up with the factory CD/TV/Sat NAV system in my new car.
steve charges 100 an hour for translations mate..hope your pockets are deep! :P:):(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
