hey guys, my R33 keeps shaking including the steering wheel only when im doing between 108km - 120km then after that its fine. I just got the car alligned and balanced and it fixed it for the day then its back to its shaking self again after the next day.
any suggestions?
https://www.sau.com.au/forums/topic/184633-wheelcar-shaking-between-108-120kmh/
Check the virtical control arm between the upper and hub for play. The load bearing in there may have play and cause vibration due to wheel instability. You should also check your castor rods to see if the bushes are split and leaking oil. Failing that, I would be looking for a strut failure or leak.
Just a thought but the weights from the wheel balancing hasnt come off has it? Happened to mine and since it fixed itself for the day maybe it came off after the day.
Edited by G_Force
When they did the wheel allignment the bushes were leaking a bit- but they tightened it up and said it was all good.
If all the wheels are balanced, i would be checking the steering rack bushes or check if there is play in the rack ends, ive just a real bad case of the my friends car shaking very violently, found the steering rack bushes were disintergrated and tightening them wouldnt do a thing. You can get these bushes of ebay, pretty cheap, look for d-project bushes. hope that helps
how long has it been happening before balancing? maybe rims wasn't put back on properly. Do you have aftermarket rims? check if the centre hub is the right size, otherwise the rim won't be truely centered, and 5 studs won't be strong enough to keep it centred after driving for some time. it only takes just a few 0.xx mm off the centre to cause vibration. It happened to me when upgrading my stock rims to aftermarket, need to go back to the rim shop to get some centering hubs.
or perhaps the rotors need machining? with my old rotors that fixed the vibration for quite a while (until I swap to 17" rims - then it became the rims' problem).
well if as you say the wheel alignment fixed it then I'd go with the wheel alignment bolt not being tightened up correctly and has come loose after a day returning you to your previous settings. Get it re-aligned at the workshop or at least go back there to tell them the problems back
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
