I own a GTST Series 2 R33.
Does anyone own one aswell and is running a slide highflow?
Compared to stock turbo how much laggier is it?
What sort of kws u getting out of it?
How long u had it on your car for?
Mods Include -
POD
FMIC
Power FC & Controller
Apexi Boost Controller
Soon to have 555c injectors
Would i need anything else? would it puch 260kws on a SAFE tune?
Thanks
https://www.sau.com.au/forums/topic/184705-slides-highflows/
My cousin has one on his R33, just with cooler, turbo back exhaust.
Doesn't seem muc laggier, only a little.
Pulls very strong on boost all the way up to red line. He has had it for at least a few thousand km's with no issues.
I also want to get one for my R32, but SLIDE doesn't make any high flows anymore..
VG30 max over size high flow would be better for 260rwkw and above.
Edited by abu
But GCG do Ball Bearing not Journal... so itll spool like 100-200rpm faster or someshit like that.
If you ask GCG maybe theyll do a Journal Bearing for cheaper.
Edited by Pauly33GTS-t
Yep same problem here.
Not I am also undecided on what to get.
Just a a HKS2530 or something similar to that, maybe even a HKSGTRS.
yer my problem is i dont know enough about turbos to make a good decision!
If you are only looking to make 300 rwkw or less i would vote the GTRS or the GT28rs hands down.
Anything over this and you would be looking at something like the GT3071 or something similar.
From what i have read these are the two best turbo's for around the 300 rwkw mark without losing too much driveabiolity as an everyday car.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
