I own a GTST Series 2 R33.
Does anyone own one aswell and is running a slide highflow?
Compared to stock turbo how much laggier is it?
What sort of kws u getting out of it?
How long u had it on your car for?
Mods Include -
POD
FMIC
Power FC & Controller
Apexi Boost Controller
Soon to have 555c injectors
Would i need anything else? would it puch 260kws on a SAFE tune?
Thanks
https://www.sau.com.au/forums/topic/184705-slides-highflows/
My cousin has one on his R33, just with cooler, turbo back exhaust.
Doesn't seem muc laggier, only a little.
Pulls very strong on boost all the way up to red line. He has had it for at least a few thousand km's with no issues.
I also want to get one for my R32, but SLIDE doesn't make any high flows anymore..
VG30 max over size high flow would be better for 260rwkw and above.
Edited by abu
But GCG do Ball Bearing not Journal... so itll spool like 100-200rpm faster or someshit like that.
If you ask GCG maybe theyll do a Journal Bearing for cheaper.
Edited by Pauly33GTS-t
Yep same problem here.
Not I am also undecided on what to get.
Just a a HKS2530 or something similar to that, maybe even a HKSGTRS.
yer my problem is i dont know enough about turbos to make a good decision!
If you are only looking to make 300 rwkw or less i would vote the GTRS or the GT28rs hands down.
Anything over this and you would be looking at something like the GT3071 or something similar.
From what i have read these are the two best turbo's for around the 300 rwkw mark without losing too much driveabiolity as an everyday car.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
