I work for a residential builder who does almost everything in house as a designer/draftie and we are in desperate need of an experienced estimator. This is kind of like a quantity surveyor for commercial jobs. We have tried the usual job agencies with no luck so far; so, if there is anyone out there who is or knows an estimator please give me a call or PM.
Regards
Donnan
0416 051 224
https://www.sau.com.au/forums/topic/184945-estimator/
I'm looking for a champion Systems Engineer... one who really knows their sh!t.
Also, are there any SAN specialists out there? Really gotta know your stuff though.
I am champion systems engineer :blink: well not really give me 2 years, that's the goal... On that note I will also put out an APB for any good Systems Engineers or Systems Developers must be proficient in Microsoft Technologies.
I do have a good mate though who is a SAN specialist although unless it was bloody good $$$ he wouldnt be interested in leaving his current work.
https://www.sau.com.au/forums/topic/184945-estimator/#findComment-3349890
HEY I waz first on the Systems Engineer LOL
We're paying pretty good money if they know their stuff.
https://www.sau.com.au/forums/topic/184945-estimator/#findComment-3349926
  • 1 month later...
Hi everyone, since this thread was already here thought I'd use it. Due to uncertainty at my current work (tied to contract) I'm putting out some feelers in regards to work out there. I have a few years Helpdesk experience and am currently studying for my CCNA. So if anyone knows of any positions in that field, send the details my way.
thanks
https://www.sau.com.au/forums/topic/184945-estimator/#findComment-3448695
Donnan, serious question: What does the estimator job pay and where are you located? Is it a contracted position or wages? How large or small is the firm and what volume of work does it involve. Feel free to PM if you prefer and I will pass your answers along.
https://www.sau.com.au/forums/topic/184945-estimator/#findComment-3448836
CyberGay sorry Cybertrust where and maystill be hiring servicedesk staff.
As this is up here I am in need of a new job... Windows Admin or server support
They finally kick you out? :P
I believe my new employer may need some winblows admins.
https://www.sau.com.au/forums/topic/184945-estimator/#findComment-3458520
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
