gay plastic screws...
Guest Boxhead
 Share
Guest Boxhead
how the f*ck are you meant to get these things out, i have tryed 3 times, and failed.. they need a bit of presuure, but then you f*ck em up.. there mans worst invention.. they are useless, why not just put metal ones in that work... FFS!!!!!!!
If they're the ones I'm thinking of, they're called scrivets (as in screw rivets!) But yeah, they're designed to be pushed in in one second flat, and spread out the base to hold things down (as a rivet does) but able to be unscrewed (never the case). Just get a tiny screwdriver, get it under the edge of the centre part of the screw and without pushing down hard unscrew the screw part. Sounds easy, and really it is. This should get even the most stubborn ones out. If not, if you can get your hand under neath the bumper part, squeeze the parts that are on the bottom of these scrivets so that the thread on the thing can grip, and unscrew itself whilst you undo it :)
Hope this can help you out in some way :):)
Steve
 Share
