  • 1 month later...
Round?:nyaanyaa:
Lol, jokes... It's actually tighter than my daily Mazda 323.:thumbsup:
Yep, Id say its on par if not better than our 2002 Ford Laser and similar vintage Focus; which imho is pretty good considering how big they are!
Essentially the same car as my 2000 323 :thumbsup: .
Frankly I don't get it , they all have CV jointed front axles, so theres obviously no excuse for a tiny car having the turning circle of USS Missouri...:whistling:
Thinking something like this: http://www.carsales.com.au/all-cars/private/details.aspx?R=10515168&__sid=12FDF7FEDAFE&__Qpb=true&Cr=0&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&keywords=&__N=1216 1246 1247 1252 1282 4294963846 4294960181 393 412 898&PriceFrom=393&PriceTo=412&seot=1&tsrc=allcarhome&__Nne=15&trecs=20&silo=1011
What do you think?
Thinking something like this: http://www.carsales....words=&__N=1216 1246 1247 1252 1282 4294963846 4294960181 393 412 898&PriceFrom=393&PriceTo=412&seot=1&tsrc=allcarhome&__Nne=15&trecs=20&silo=1011
What do you think?
man i wouldve so traded you mine if i didnt have this boost issue and you were in VIC. VERY NICE chaser!
What do you think?
Looks nice, only down side with that one (imho) is the integrated bose stereo - meaning you cant easily just put in a new single/double DIN stereo - and if it (the bose stereo) dies, it takes the aircon controls out with it.
Id check the 'For Sale' section on here - I know a few guys are parting ways with their Stags at amazing prices at the moment; but unsure of where they're located.
What do you think?
Whilst I like the Dayz bodykit and Autech interior...
... I received an email about that particular M35 months ago. Pretty sure it had considerably more kms on it back then (if it is the same car of course - but you don't see very many black Dayz kitted M35's).
Aaron - Cheers mate. Will have another look in for sale section again. Did find one but I think he has sold it now. But first need to sell the chaser before anything else.
Dunc - Thanks for letting me know about the Bose stereo issue. So has anyone successfully removed and replaced it with a newer head unit?
iamhe77 - Interesting.. hmmm sounds sus (if it is the same car). From who did you get the email from?
Theres a few different options; you could buy a new/used centre console, AC controls, etc from Japan and get all that fitted - or possibly some half way method whereby you 'cut' up the console. Best person to speak to about your options with it would be Chris Rogers (hes a member here on SAU) - hes somewhat of an expert with all things electrical in the M35 and V35 :thumbsup:
It was an email sent by imports101 prior to the current company advertising it.
Btw, the current company had it advertised initially at $24,990 (about the same as what a 2006 Stagea would set you back), but that was prior to it landing in Aus.
*Hint*
If you want an M35, look at the ones available on this forum, most are from members that are pretty up to speed on these cars... or if you want a dealer warranty, get an M35 from Northshore Prestige. They really do find top examples and don't wind the kms back.
*Hint*
+1 to that; they've got a black M35 on there with a bunch of Nismo options (exhaust, spoiler, suspension) at the moment - quite reasonably priced too! Id be checking that one out for sure :thumbsup:
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
