Well guys.... I opened the PFC up when I got home from work just then and was greeted by the extremly stong smell of burnt out electrics, so my worst fears have come to be, while I cant actually see anything on it burnt it has the very distinct smell of when electronics are fried.
Is it possible to have these things fixed does anyone know of anybody in the Sydney area that can fix them?
If not what are my other options I cant go back to stock ecu as I have aftermarket turbo, injectors, z32 afm etc etc.
Thanks
  • Replies 51
Posted Images
hmm that sucks. You can go back to standard ecu if you want they can be remapped. since its an rb20 you have buckelys of getting a pfc for a decent price.
btw putting the battery terminals on backwards is only dumb, not stupid. leaving a washer in the intake when you bolt it back up destroying your motor AND turbos is stupid.
lol.. :wave:
No fuel pump buzz, no pfc h/c display, car cranks for eternity; sounds very familiar.
Don't ask how I know this but take it to an elec. shop with the ecu pinout and they will fix it. Should cost around $100 to fix. :)
From memory the resistor on the main line is the one that dies.
Also check the main 75amp fuse within the engine bay relay box; that 'should' also be blown. The 75amp fuse isn't cheap either.
i know the shipping cost will probably double the price, but there is someone on Ebay.co.uk selling the fuses for £2.50 each...
i bought 2 30A from them and they are selling all for the same price.
lol.. :)
Haha Cubes you did the same thing did you?? Yeah after closer inspection I discovered the the 75amp fuse was blown managed to pick one up from Repco for $11.
Now I will look into getting it repaired I hope it isnt too far fried beyond repair, does anyone know where I can get this ECU pinout so I can take it to an electronics shop with me?
Was talking to my old man about this one, he is a micro lecy from way back. he was saying that all cars have whats called "crowbar" protection, bascially there should be so many fail safes and stuff between the bat and your ECU that it shouldn't be damaged.
if your low on cash is prolly worth really getting you hands dirty, err dirtier... then you already have to find whats let go between the source and ECU.
i wish i knew more about your problem and PFC's to offer better help, hope its not the worst case situ
Hey mate thanks for the suggestion but I have tried the PFC on a mates R32 and it doesnt power up on his at all either so its definately the PFC.
And cheers for that link Cubes ill contact them soon.
Thats correct but unfortunately with the skylines the ecu most definitely does get damaged.
In the process it also blows the 75amp fuse as well as one of the fuses under the dash. I forget which one.
Luckly the ecu blows the main resistor and protects the bits within.
Also note that the thread op could smell an elec burning smell so it has obviously been toasted. :S
yeah, thats a awesome way to check it :P, sucks dude was hoping it would be something more dispoable for ya.
so its abit of design floor then, thats pretty off Jap design.
Hey thanks alot mate... I dropped the PFC off yesterday to Automotive Service Solutions who specialise in fixing ECU's, they said they would give me a call over the next few days to say weather it can be fixed or not so ill keep everyone updated once I find out.
Alright guys I have an update,
I got the PFC back from the repair shop today, put it in the car it turns on the fuel pump primes the hand controller comes on etc, but the car still just cranks for eternity and will not start, ive checked all the fuses 1000 times and their all fine. Anyone got any more suggestions before I burn this fu**ing thing.
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
