Hey Guys just wanted your opinion. Ive been looking at some of the ECU postings and Ive been reading people discussing how the Power FC is old technology. What you guys think?
Old Yes.....But Still Effective, Just misses out on some of the Newer stuff available today suck as anti-lag, Ignition cut, Multiple maps ect.
But gains with its plug and play factory style management.....ie You can plug it in and drive.....no need to worry about light load maps, cold start etc.
I swear By mine (R33 GTS-t)
Yeah if they were never discontinued all this talk about PFC being outdated wouldn't have come about.
Its because they're no longer the cheapest and most effective option for its price that its been labeled old and outdated.
Honestly if you could still buy them for $900 odd dollars, would you still say its not a good option? Would you still say get an EMU over a PFC? Some will say yes, but I know plenty would say no.
For the price the discontinued ones go for now, you can pick up later and greater ECU's with more options than you can poke a stick at.
But its time to move on, just accept they're not any longer a very feasible option and you can get something else that will fill your needs anyway for the same price.
But if you can pick one up for a reasonable price then I'd say jump at it. If not don't worry about it and get an EMU.
I bought a PFC just after they were discontinued, got it just as their prices started to rise. It wasn't cheap, but not overly expensive either. I don't regret buying it.
Edited by KeyMaker
"Old" and "outdated" are two different things. Internal combustion's no spring chicken either, but its not like an electric motor going to replace it in a production capacity in the near future. With crude oil "running out", most of the effort to resolve this issue is still going into changing what goes into an internal combustion engine, not the method it converts stored energy into kinetic energy.
The only thing people don't like about the PowerFC, as an entry level "plug & play" ECU, against more modern offerings is an inability to store/load multiple maps within the ECU itself. However, if A'PEXi were to release a new version it wouldn't be a massive step to integrate such functionality. Some memory and a switch / menu for the hand controller would be all that's required.
I hope A'PEXi (or someone else) does replace the discontinued PowerFC, with that extra functionality (and a ECU for the VQ series engines).
Well you can still get a PFC for $900 for a RB26
So IMO they still hold their weight.
The fact it comes with a base tune is also a winner.
Other ECU's might have launch control, or some other feature. But honestly, when are you going to use it in a street car?
Plus we are talking cars 10+ years old now.
As Ash said... Its an excellent option for a street car.
It cold starts, warm starts, idle's, cruises and operates the a/c like a factory ecu.
I wouldn't consider it 'outdated' as it still offers features that only the top end ecu's worth more than 2x its price do.
6x injector drivers (Sequential Injection!), 6 x coil drivers, overrun fuel cut, closed loop o2 control just to name a few. :thumbsup:
Most importantly it just works. Which results in cheaper tuning costs that tuners 'should' be passing on to their customers.
100% agreed. for a plug n play to do all these things, it should be highly recommended
I have a POWER FC in my car..and I really don;t know exactly what it does..but is a...MUST. Hmmm hate to disapoint you but we have the same combustion engine since 1800... still I love my line...don't you?????
Cheers,
eug.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
