sucking and blowing then swapping?
Wastegates actuators could be stuffed ie. the spring opening the wastegate at any pressure
To test that remove the hose running to the actuator and rev and see if it makes any more then 0psi
Edited by str00th
  • Replies 56
Posted Images
ok, well if theye are both sucking, and wooshing etc etc. then they work.
heres what to do next. you need to block off the blowoff valves. (the pipes that come up to the airflow meter pipes.) idealy you want to block them where the are. (drivers side brake duct)
this is just a random thing.. but i saw someone postin, that if 1 turbo dies.. it halves the boost???
just thought id let u know and everyone else that doesnt know, that twin turbos dont work like that.. 1 doesnt make 3.5psi and the other one another 3.5psi.. otherwise ud be able to run more than 14psi on a ceramic turbo.. they both make the same boost.. but because theres 2 turbos, the actual flow is twice as much.. so if one T28 makes 400cfm @ 7psi.. then two will make approximately 800cfm @ 7spi..
as for ur no boost... its not gonna be turbos.. i still think its ur bovs.. theyre sizeable enough to leak all ur boost, without stallin ur car (they are a valve after all..) what might be happening is a vacuum line going to ur bov's might have been severed.. They need pressure in the line to stay closed and then the pressure in the intercooler piping plus the vacuum in the vac lines (going to bov) opens them up during no throttle.. maybe theres no pressure in the "vac" line to keep it closed..
Shit hey 240?
I allways get ripped off. All well.
UPDATE TIME: Taken BOTH turbos out and to BUST all your bubbles it was the rear turbo. The exhaust wheel have come off and logded it self in the turbo. The front wheel wasn't turning nor was the rear. The shaft in the middle was snapped. Pretty f**ked up hey!
PICS come tomorrow. Such a relief that it was the turbos because i got abit worryed when everybody thinks it's something else. The wastegates were fine. Everything was fine. No leaks in the system no leaks in the BOV's. It was that turbo shaft that was f**ked.
All well. Now it's time for the INSTALL. Probly going to take as long if not longer. So far it's taken 7 hours to take them out...
yeah. bovs is the next logical step. ps.. with no vac lines hooked up it will still hold 10 pound :ninja:
no boost at all? does it sound abit funny out the exhaust? id be suspecting a ceramic turbo failed. ive had ones die on standard boost with no mods.
Shit hey 240?
:ninja:
UPDATE TIME
Finsihed putting the new turbos on. Thanks Hyperdrive Motorsport f**king legends! BOY O BOY the difference the new turbos make. The old ones must of been f**ked or piping isusses? Anyways did some upgrading of the old clamps, bolts, gaskets,nuts ect and the differnce is F**CKING AWESOME. Spool time is nearly instant and power pulls something curl! Another thing is i can here the blow off values heaps more now. Whats the go?
Blocked cat usually it will feel flat and retarded one blown turo will result in no boost what so ever and the symptoms you described cat is a remote possibility but being a GTR dave is going to be right in that its spat an exhaust wheel.
Hmmmm way back on page 1!!!!!!!!!!!!
Edited by Risking
Sorry if i didn't believe you guys way back on page1 but it is alot easier to remove your cat then to remove your turbo....
It's not making more boost becasue it's still making 0.8bar. Just feels alot more boost but not. Thanks guys.
<object width="425" height="350"> <param name="movie" value="
</param> <embed src="
type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
I made it to the show and shine in Geraldton on sunday. I did a dyno run and got 201 with winding out 4 and hitting the 180 limit. Theres the video!
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
