Hi guys,
Obviously there are quite a few guys on here making that kind of power....so i was just wondering how much petrol do you use? I plan on getting my car tuned and want to make around 300-330rwkw's but kos its my everyday car i just want to know roughly how many k's im gonna be getting out of my tank....
And i may as well ask at the same time if you guys think i should be able to achieve my target with the following mods....
- Rebuilt engine (forged internals, etc)
- Garrett GT2860r -5's
- Trust cams 264" 9.1mm lift (not yet installed)
- Adjustable cam gears (not yet installed)
- 550cc injectors (not yet installed)
- Z32 AFM's (not yet installed)
- X-Force dump/front pipes
- 3.5" Kakimoto exhaust
- Power FC (still need to get)
- Turbosmart eBoost2 (still need to get)
So im hoping with this set up ill be able to get 300-330rwkw with about 18-20psi.....
Cheers guys!
i dont see why you cant get 400k's to tank with 500rwkw
its how you drive it on the street, if you load it up, its going to use fuel, simple really?
if you drive normal, it won't waste fuel.
this asumes you dont have stupidly large 2300cc injectors and your ecu supports 02 closed feedback and the cruise afr's have been tuned
haha....yeh nah not too concerned about fuel economy, just seeing roughly what i was getting myself in for...i do roughly 450k's a week so if im using almost 2 tanks a week just to get to work then im looking at bout $150-160 in petrol...haha, GOOD TIMES!
yeh i've read a few of those threads, so ill hopefully get it....but i've had pretty sh#t luck with the car so i wont be surprised if i only get 270-280rwkw... :(
you should be able to do 450k's on a single tank
i suggest you review
how you drive (get your gf or mum to drive the car for a week, i bet they can do 450k's to a tank)
your 02 sensor (they need to be replaced peridocially, if youve never done it, change it)
your ecu & tune (cruise afrs make all the difference & make sure 02 feedback is on/supported)
  • 3 weeks later...
i dont think you will have any problems getting into the 300rwkw mark. Petrol becomes an issue when making that sort of power. im a tad over 300 in my 33 gtst and getting around 200-250kms to a full tank.
jesus thats bad im making 380-400 a tank and im above 330rwkws....
rwkw doesnt have much correlation to fuel economy unless you are like 2000cc or insanely large injectors
its how you drive and how you yank the throttle cable and how well its tuned
there should be no reason you cant get 450ks to tank with 300rwkw
^ exactly on the highway ie last trip from adelaide to melb the R32 GTR (350rwkw 700cc injectors tomei pump PFC) averaged 650kms.... around town expect 450-500 depending on right foot. Stay away from fuel pressure regs and spend the extra on a decent pump.
how much fuel you use more depends on how much time you spend on boost. the more time spent on boost the more fuel you will use. also what sort of driving you do also makes a difference. the term city driving doesn't mean much these days. i drove from albany creek in brissy to mt gravatt and only had to stop about 3 times in 45 mins. that trip would've used a lot less fuel than if i had done it in the worst possible peak hour traffic. if you sit dead stopped in traffic for 20 mins a day (10 mins on the way to work, 10 mins on the way home) you will be wasting a fair bit of fuel every week.
Yeah mainly to do with your driving, assuming you have a good tune.
But on a car fitted with a big turbo, you tend to put your foot down more off boost, which is most of the time if your car is really laggy. Compared to a responsive stock car, where you just have to curl your right toe to get moving.
Edited by Yawn
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
