Item: Custom Low Mount Manifold
Extra Info: Brand new, never been used, Stainless Steel low mount manifold (keeps the turbo on the original location)
has external wastegate pipe. Improved flow and diametre from stock manifold.
Reason for Sale: I have bought a new HKS manifold, so I didnt end up needing this one (need to recover some of the $ from the HKS :( )
Location: Adelaide, but will deliver interestate for an extra fee.
Price: $350 ono
Pics:
Cheers
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/186416-exhaust-manifold/
can I have first dibs, after I see pics and find out a bit more on the item?
I'm keen to buy on these conditions:
1. It bolts the turbo to the exact same position as the standard manifold
2. Its decent 3mm stainless rather than the 2mm chinese copies
3. I get to see lots of pictures :(
If they are all met, consider it sold
Edited by The Mafia
We are talking about the location of the turbo, no one said anything about stock turbo mate, and fyi even with stock turbo it can be modded to suit external gate.
If you are not interested please refrain from posting.
Edited by Richo
how does a stock turbo work with an external wastegate pipe????
You could just use a block off plate if you had to.
Any idea who made this or is it an ebay chinese special?
Also did you fit it, if so how did it fit?
I'm keen for answers to these questions also
You expect ppl to beleive it's new when there are obvious signs of use?
No an ebay job.
Its a Tune Agent manifold customized to fit external wastegate, yes it was test fitted, no dramas.
Mafia let me know asap, cause I have another guy interested.
Cheers
Ric
Thats is another flange that was welded to the original flange to better fit the turbo, it was all done when test fitted. Its a new manifold, you obviously dont know how a used SS manifold looks like. :)
Edited by Richo
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
