Item: Custom Low Mount Manifold
Extra Info: Brand new, never been used, Stainless Steel low mount manifold (keeps the turbo on the original location)
has external wastegate pipe. Improved flow and diametre from stock manifold.
Reason for Sale: I have bought a new HKS manifold, so I didnt end up needing this one (need to recover some of the $ from the HKS :( )
Location: Adelaide, but will deliver interestate for an extra fee.
Price: $350 ono
Pics:
Cheers
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/186416-exhaust-manifold/
can I have first dibs, after I see pics and find out a bit more on the item?
I'm keen to buy on these conditions:
1. It bolts the turbo to the exact same position as the standard manifold
2. Its decent 3mm stainless rather than the 2mm chinese copies
3. I get to see lots of pictures :(
If they are all met, consider it sold
Edited by The Mafia
We are talking about the location of the turbo, no one said anything about stock turbo mate, and fyi even with stock turbo it can be modded to suit external gate.
If you are not interested please refrain from posting.
Edited by Richo
how does a stock turbo work with an external wastegate pipe????
You could just use a block off plate if you had to.
Any idea who made this or is it an ebay chinese special?
Also did you fit it, if so how did it fit?
I'm keen for answers to these questions also
You expect ppl to beleive it's new when there are obvious signs of use?
No an ebay job.
Its a Tune Agent manifold customized to fit external wastegate, yes it was test fitted, no dramas.
Mafia let me know asap, cause I have another guy interested.
Cheers
Ric
Thats is another flange that was welded to the original flange to better fit the turbo, it was all done when test fitted. Its a new manifold, you obviously dont know how a used SS manifold looks like. :)
Edited by Richo
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
