I had my R33 series II couple of weeks ago, car in good condition and good power with a few mod like:
Apexi power FC
Bosch 040 fuel pump
NGK spark plugs
Manual boost controller 12 psi (dun know whether stock turbo or mod one)
Front mount intercooler.
Apexi turbo back exhaust 3.5" with 4" tip
Excedy heavy duty clutch
One day I drove a bit agressive and power FC read 240 on knocking level. I know it is something really bad cause the seller told me that this car now have been tune for economic drive to safe fuel and dont drive hard unless get it tuned properly (which will worn out my pocket for fuel). I'm a nope in performance car and dun know wat I should do now. My mate told me to bring it to dyno tune to check up wats wrong with it and tune it back to normal. Can u guy give me any suggestion of wat may go wrong with the car and how can I solve it. I appreciate that.
https://www.sau.com.au/forums/topic/186430-knock-level-reading-240/
Man 240 knock is pretty bad, if you just bought it you should of taken it to the dyno first thing to get it tuned. Take it now to get it checked out and I hope everything works out well. Get a compression test done aswell while your there.
actually it'll do the opposite, make the air less dense actually richening it, however because the combustion mixture is hotter it will reach it's flash point sooner and therefore knock easier :domokun:
get the car tuned asap, or if that's not financially viable do a little home tuning on the ignition map.. do a map trace to find out what cells the car is knocking in then retard the ignition in those sections.. Pauls PowerFC FAQ will tell you everything you need to know :P
Avoid working the motor - making it knock - until you get it tuned. And get it tuned soon, summer heat is just around the corner and it will lean the motor out even more.
Edited by aphid
i've seen stupid knock readings like 280 on a car that had a stuffed engine mount. the vibration of the metal to metal contact was enough to give a false reading. any noise, vibration, hit can give a knock reading. tapping the side of you engine with a hammer is enough to get a reading. also check to see if anything is touching(bumping) agianst the engine.
i myself have had readings of like 160ish from when i had the safcII and i hit rev limiter. don't know if the safcII runs the same knock system though.
another option is that the knock sensor has stuffed.
I had a knock reading of 158, took it for a dyno and knock would max out at to 29 for about 3 weeks, now its back up to 145. Have no idea whats going on. So yeah, don't get on the gas until you sort it out bud.
around 4800 there seems to be a noise on Neo's which i believe is the VCT. knock sensors seems to read around 140'ish at this level. no signs of knock above or below, just at this point. ryan, is this where you are getting the higher knock readings.
Edited by wolverine
Thank for reply guys. I dun really know wats happening with it. I drove today, 3rd gear at 2800rpm, go up hill and the nock just jump from 15 to 57, any reason why suppose that car hace been drove for an hour. I tried to drive it soft but the retard sensor keep giving me a freaking number that really making me shock. I'm about to bring it to dyno tune next week and quote the price for $450 for a full tune or $250 for standard one maybe, any idea about the price ? reasonable ? Cheers.
hi,
have a read of http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm and pay attention to;
Tuning Information
53). I always have knocking, is it true, is it lies or is something wrong?
54). How do I debug knocking, how can I make it go away?
you can sort it out yourself if you like or learn more about it, to better understand the issue
Yep that would be about right, always in 3rd gear too, under load light starts flashing i look across and see the reading on the handle controller.
hi,
Tuning Information
Nice work mate :(
What fuel r u using?
Go get it retuned .. id spend the extra dosh n ask for a full workover of the map, make it for performance .. Its more fun anyway.
Not to clued up on pfc but cant you install more than one map?
Anyway good luck.. Id avoid driving it in high temps as well, check your cooler and pod/air filter that they are clear to just make sure the engine is gettin all it needs.
when I had a the knock I used 95, but change to 98 now and I also change a igntime back to 1 deg and it works well.I just wonder if I keep driving like this will it be a lot of effect to the engine and also sone one had told me about the workshop can "clean up" the knock when I bring car to do dyno tune, what they acttually do to "clean up" the knock and what is the acttual dammage knock cause to the engine, for exp engine crack, blown, freeze.. etc.
Coz i'm only do daily drive so I'm still consider about the running cost, for sure get the car tune up to a proper performance can be cossy in long term drive. And fact that the previous owner had tuned it back from the performance just be cause the fuel economic.
Cheers,
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
