hey guys, in the coming months i want to change the basic standard turbo setup (internally gated) to an externally gated setup.
to do this i will get a custom low mount manifold, with a external gate pipe. and an externally gated turbo.
in doing this will there be any mods i have to make to the exhaust/dump pipe.
i am new to this external conversion
so any tips would be appreciated.
edit= the info given here could also help other ppl out ther
Edited by r33cruiser
well for starters lover boy you'll need an external wastegate. the turbo itself is not 'externally gated' it's just a turbo. with no internal wastegate.
and yes of course you will need completely different dump pipe and most likely front pipe too.
Well using a new manifold, its all going to be in a different position.
You'll need a new dump regardless, as the non-gated rear is a different design, and position (with manifold) will require it changed.
How much more of the exhaust changes depends on how big the current dump is, but minimal either way.
