  • Replies 103
Are there dates on this yet? I'm keen to go.
No reserved spots is fair considering they had to turn their own members away. I'll get my bank of fax machine all cranked up and ready to attack.....
And Autosalon over DECA - guess those would wold rather look at cars than drive them should go to Autosalon. Lets see, how good do you have to be to drive on a Dyno?
I am waiting for Snowy to get back to me TJ i think it is around the 1st of dec or somthing like that but we need to sort out some where to sleep as the place we stay at is already booked out !
dam mexicans!
And Doof I am not drunk you are !
I dunno... those dyno ramps can be hard to negociate.
Well the only reason that you won is because i was driving smokys car and we blew it up so now the GTR is coming out to play and let me say wont be like you remember it MMMWWWWWAAAAAAHHHHHH
come here big boy@@!!!!!!hahahaha
RWD ftw and tou know it@!!!
everyone knows i am the deca nsw man! hahahshshaq
ah crap, gonna be soooooooooooooooooooooooooooooooooo hungover on caturday i mean saturday
Craig, the only reason u want in is cause im not there and you k ow that meand I cant come first for NSW1 :ninja:
ahaha
rofly at dstarting new threwad!
Go to sleep you drunk
Sif you will be driving it hard/fast
You think that purple thing of yours is going to beat the TJ in White Knight? You so silly Lucy.....
HA HA HA HA funny TJ but they are fighting words Just think if i can come second in a GTST with no experience in driving the car wonder what I can do in the purple people eater LOL
GAME ON!
Im suprised you will drive it that far from its garage :(
:worship: Listen to the man, he's right :rofl: driving all that way to get your ass whooped on and off the circuit is insane. But hey i guess VIC is "the place to be" ;)
My car will hopefully, finally, make an appearance. It may not get in the top twenty, but it will surely look good frying the tyres :)
Craig, the only reason u want in is cause im not there and you k ow that meand I cant come first for NSW1 :)
ahaha
are you drunk :laughing-smiley-014: the Dr said not to take those pills with alcohol.
whats the power of it?
GAME ON!
Game on mate....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
