Guest Sim32
17..wow..hey mate ive been in 11.4 seconds yellow r34 gtr v spec..and let me tell u this is one of the most phenomial cars i have ever been in..alongside a ferarri f355 :) not even for straight line speed..but just for handling..the whole setup is great..but yeah..even standard u will be suprised...
so have fun..just make sure u pay the phat insurance bill :(
https://www.sau.com.au/forums/topic/18747-hello/#findComment-394364
lol, i have a quote for insurance at almost $7000, so since i still live with my parents they have agreed to register the car under there name so i could get it insured for $850 a year. The only problem is if i crash it, i will have to pay a shitload extra :) but i dont plan to crash such an awesome car !
https://www.sau.com.au/forums/topic/18747-hello/#findComment-394371
using money from your trustfund to buy a $80k+ car as your first car is the stupidest thing I have heard, and your parents letting you do it is even funnier.
why dont you wait until your like 25, and on a rating 1 or something, start with a cheaper car so you can get some driving experience, and cheaper insurance as well as easier rating. you gotta taste the sour before you can appreciate the sweet :(
but good luck to you none the less, your gonna need it :)
https://www.sau.com.au/forums/topic/18747-hello/#findComment-406298
God, i think some of the old boys here have forgotten what it's like to be 17. No matter what anyone tells you, you don't listen. If you've got your heart set on it and it makes you happy then go for it. If he's telling the truth, then nobody here knows what his situation is.
But, still, if you asked me, i'd say buy something with a little less power to start with. At 18 and with no real serious driving experience, even a simple r32 gts-t can get you into a lot of trouble if you don't know how to handle the power.
https://www.sau.com.au/forums/topic/18747-hello/#findComment-406423
yup me being 17 we dont listen to the old folk we figure things out for ourself either the easy way (buyin a cheap car) or the hard way (buyin the gtr and gettin killed by the insurance) let him learn if he wants to blow $90k on a car and im betting over $5k on insurance a year let him he'll learn
https://www.sau.com.au/forums/topic/18747-hello/#findComment-406439
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
