I'am currently importing a car through them and they seem to be handling everything very well. I know people that have bought cars from them before and there service during and after the purchase is great. The new man in charge (Alistair) seems to be a nice guy and good to deal with. I imported a car through imports101 at the beggining of the year and to this point of time i'am much happier with autoworx.
https://www.sau.com.au/forums/topic/187513-autoworx/#findComment-3383956
Did they say how long the car will take to arrive at Aus? Were you given a VIN number before bidding for the vehicle ?
https://www.sau.com.au/forums/topic/187513-autoworx/#findComment-3383978
yeh i was imformed as to how long the car would take to arrive, but as i missed this months boat mine leaves japan end of next month so it will arrive about 10th november then it must go through customs then goes to there work shop, and yeh they give you the VIN before bidding, along with heaps of photos and any details that you must know.
https://www.sau.com.au/forums/topic/187513-autoworx/#findComment-3384005
Same, I bought my R34 just before Paul sold up, I was very happy with the service then, and Alistair has succeeded in filling a big pair of shoes! He is uberfriendly and is very helpful... I'd go back again.
(EDIT) - Don't post when on the border between still drunk and getting hung-over ;)
Edited by Marco-R34GTT
https://www.sau.com.au/forums/topic/187513-autoworx/#findComment-3387076
Thks for the replies guys. Btw, how long did it take for you guys to finally drive the car from the moment u placed the order for yr car ?
Might be heading there early Nov. You reckon will i make it b4 Xmas or at least 2008? Will there be major delays considering it's the Xmas season?
Edited by hotchoc
https://www.sau.com.au/forums/topic/187513-autoworx/#findComment-3387134
    • Yeah i have R34 with factory small box and now RB25DET NEO swapoed and iam planning to upgrade to big box.  So i would be good as long as i do not change diff?
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
