Sounds like a rippper of a plan to me, not bothered bout the date coz where there is modified cars, corners. i'll be there
Yippeeeeeeeeeeeeeeee GOR here we come. :bunny:
regarding the south east meet (mini cruise up to Avalon), how about Brandon Park again?.......
Edited by SRZILLA
  • Replies 229
Posted Images
sounds good!
sounds double good.
for the last GOR me and dilmah had a meet point at stud park and we got about 10-12 cars so ye expect the same for brandon park maybe even more.
oh dan dont bother asking or waiting for his reply just put dilmah down he will be in for sure to lol.
hope fully by then im lowered and rims
DNGRUS: yes there will be a kmart pre meet, will organise that in the events section once a date is decided on
Ashneel: if u organise another pre meet, go right ahead, will still have kmart meet like last cruise
Everyone else: list updated, 24 hours in and we have almost guarenteed 15 cars already
Edited by cheez
schweet mate ill start one once the dteas are confirmed. maybe have like one thread for pre meets and put down the different pre meets on the first post. that way ppl know exactly where they all are
man im getting excited alread lol. make it the 25th. the sooer the better. ;)
Excellent idea re the pre-meets - will avoid confusion ;)
Good job guys on getting another open cruise organised - they have been scarce the last few years.
Let me know pre-meet details on MSN man!
Don't want to cruise like a loner :P lol
Edited by abu
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
