Both my cars are wearing out now, and was wondering which option i should take?
1)get some crappy pads for time being till i can afford decent ones(front and rear)
2)get some really good front pads now, and wait a while longer and get the rears as money is an option
3) you tell me
3) you tell me
G`day `nsta` HOW about rebond + you may have a choice of different bonding`s,i have series 2 stagea & have had to do this as gen nissan pad`s are outrageeous $,$60 against $192+get screwed tax,iam in perth,hope this will help,chuckie.
3) you tell me
What sort of pads are you after? As has been said, Lucas are a VERY good pad, good for 650 degrees, and VERY cheap. Its what I rally on, and can not justify spending the stupid amounts of money that ' high performance street cars' :bunny: seem to spend on theirs.
Above that you've got QFM's A1RM semi race pad (50-780) for $110 a set... Let us what sort of pads you're after, and stop spending stupid amounts of money on sbs/hawk/pagid/endless rubbish when there's better and cheaper options out there anyway.
More importantly what fluid are you running?
Get some good fronts first (since the front is where the majority of the braking occurs). Maybe also adjust your driving style so you don't keep jumping on the brakes at every opportunity, which will extend the life of the brakes.
Can I be blunt and say its your brakes man. Its really the only safety feature on a skyline... You NEED to do it properly. As has been said tho, the cheaper pads arent always bad. I've got some lucas ones, they are pretty good.
I got a full seat of pads for my 33 for $90 from my bullseye guy, a brand called 'Prime', they seem to be ok I'm running them on rda rotors... no squeals, just feels normal, not amazing but decent... ordered them in one day got em the next...
just done front and rear pads today, got some lucas ones, my olds ones were down to nothing. One slight problem, i went to fill my brake reservoir to find that its nearly going to overflow out!, what causes this, and how can i remove the excess fluid?
Think about it. You've just pushed a caliper piston back into a cylinder containing brake fluid. The cylinder is now smaller - some of its volume is now filled with piston. The brake fluid - like all fluids - is incompressible. Where is the fluid going to go?
Bleed the excess fluid out through a bleed nipple at one of the calipers.
Interested to know where you can get both the QFM pads from and the Lucas ones (located in Sydney btw)
If someone could PM me with details would much appreciate it :P
Cheers!!
If someone could PM me with details would much appreciate it :(
Cheers!!
GSL RallySport does both (and lots more) of them. Although I'm in Brisbane, I specialise in mail order and my sales are pretty well split locally and interstate. Shipping to Sydney is only $7 anyway, and will still come in under what Repco/Autobarn/Bursons will charge.
PM if you like, or what are are your requirements?
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
