HI guys, today when driving my R32 GTR I noticed that when turning at low speed the car would stop. I have checked it by driving in a car park, and it seems like the rear diff is locked, when you turn the inside wheel has to break traction, therefore requireing more throttle to turn the car, it goes fine in a straight line, there seems to be no diff slap or knock. I have had the car for about a month now but have never noticed this before. Is my diff about to shit itself or is thos normal, I called a couple of workshops but they want to see the car, they said it may be fitted with an aftermarket diff, if so I think it would be strange that I haven't noticed it till now, I drive the car every day? Has anyone else had a similar problem? The only recent mod I have done is fit a Tourque split controler. The car drives fine but whenever you turn, wheather going forward or backward it now requires extra force to move the car? HELP? icon9.gif
Edited by IDO 11S R32
https://www.sau.com.au/forums/topic/187625-help-r32-gtr-drive-train-problems/
I have done more testing, I have found now that it is not the rear diff, as stated I recently fitted a TSC (tourque split controler) maybe I have done something wrong, when I run it in 2WD mode the car runs fine and the diff works fine, when I run it in 4WD mode and take off, the front tourque indicator guage goes to 50, no matter how gentle and you can feel it load up. When I reverse it does the same thing but when I try to turn and reverse it locks up. Now could this be the TSC confusing the ATTESSA system or could I have a problem with the transfer case??????? Has anyone ever fitted a TSC and had simmilar problems?
Hey,
I have an R32 GTR as well, the rear diff is an LSD (Limited Slip Differential) which on tight U turns will cause the inside wheel to slip a bit as its trying to turn the same amount as the outside wheel, you will notice this happening a lot on gravel surfaces. It does sound like you may have a problem though, the torque gauge shouldn't be going to 50% on gentle acceleration and it sounds like you have to force it in U turns (or is it even in just normal turns?), I would double check your TSC installation like you said. Have you checked your ATTESSA fluid level recently, don't know it would cause these symptoms but always good to eliminate as much as you can from the equation.
Cheers!
Gagz
Thanks, I will check the TSC connectors again, just for further info it only does this now in reverse and only when it is in 4WD mode, in 2WD mode the car is normal, forward or reverse. It is quite weird, like I said, if you reverse in a straight line it is fine, only when you reverse and turn does it seen to lock up. THe car literally stops and requires about 2000rpm and some clutch riding to get it moving and you can feel that it is struggling. If I cant find anything wrong with the TSC I will disconnect it and see how it goes. I will post the results for information of others. Thanks
No not yet, I havent had time, been busy with work, will do some testing on the weekend and post the results, if I cant get it working I will disconnect it altogether and see how it goes. But I am pretty sure it was connected perfect, I used a soldering iron and heatshrink on all connections, but will have to check them.
Ok, I have done some testing an elliminated some things, I changed the diff oils and gearbox oil, I checked the wireing to the TSC and found that it has all been done correctly. What I have found was that when taking off from a standing start it goes to max front torque and stays there until I accelerate, If I try to turn the car while it is like this then it all feels locked up, especially in the rear, its as if I have a locker diff with the inside wheel skipping as I turn. However if I accelerate so the front torque goes down to normal then I can turn the car and it is fine. So I think that I either have a problem with the ATTESSA computer or the TSC is no good? Has anyone ever had this problem???? I have also recently put new tyres on the front but they are the same size and brand as the rear, so the fronts are 100% and the rears about 30%, but surely this wouldnt affect the ATTESSA. If anyone has any ideas please let me know, the next thing I will do is disconnect the TSC altogether and see if that works.
I checked the wiring to the TSC and found that it has all been done correctly.
Not the bloody TSC - the TPS (Throttle Position Switch)!
The rears will now be rotating faster than the fronts (smaller rolling circumference) so the ATTESSA will think you have wheel slip. Try swapping front - back.
  • 4 years later...
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
