  • Replies 285
the first guy who got one... and possibly have a radiator fetish that i just found out about wrote this about them
"Yep, and all going well it will have it's first track test this weekend. The car was running mid/high 90 degree temps on the track previously. I am hoping to see low 90's, hot enough to keep the oil clean and cool enough to keep me happy.
Some specs on the core. They are twin core not triple, but the cores are about 10mm wider each so the same effect as three rows (maybe better, less space is wasted between rows) The fin pitch is about the same as the stock core but the tube pitch is finer. There are ten extra tubes per row.
So the tubes are about 50% bigger between the two rows as the stock core and there are 25% more tubes. They should be a significant boost in cooling."
it has mounting holes for the shroud
untill i trial fit one i cant confirm 100% but the supplier says it does
mine have all been custom fit
Oh ok thanks for that.
Let me know when you have a definite answer, as I would be keen on one as long as it sits exactly like stock radiator. :w00t:
Thanks,
Abu
ok for starters they are only 45mm thick, not 50mm. the top tanks are 50mm but the core is 45mm.
The R32 and s13 (CA only) are only 32mm thick
All radiators suit gtr and gtst models accordingly
And there is absolutley no way you cant be making money off these, we are the SA distributor for these radiators. We have them in stock too for adelaide customers and if you wanted to check quality and they wont dissapoint
I just though you should get your facts straight.
hey pete ur mate got one that will fit r31 with rb20? i havent been able 2 get any answers off anyone about which will fit but im assuming r32 one would b close?
for a r31, you use a r33 radiator
as for exact dimensions and stuff all i know is they are 50mm thick and twin core, i will measure one i have tonight so i can get my facts straight
lol
i dont make any money out of these...
anyway they are a good thing if you want one come and get them
pete
So for S13, can you get one that is the 50mm core and fits SR20det?
give us a pm. cheers mate i'll get one asap if it is :D
Edited by chunda
Bought one yesterday. They look perty. The core itself is 15mm wider than stock and everything else is bigger ie:end tanks. So about a 60% increace in water capacity over the stock radiator.
Will have a report to give on day to day driving in 1-2wks. Track report a bit later on.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
