I've got my turbotech boost controller set to 10psi, and it worked great for about a week. Now when accelerating past 4,500rpm boost drops noticeably to about 5psi (although the gauge shows 5psi it doesn't even feel like it's making that much boost). It's a really noticeable drop off in power.
I took it to the mechanics the other week and wouldn't you know it, the car worked fine when I was there.. but the problem is back now. Any suggestions of where to look? Will it just be a leak in the vacuum line?
Problems driving me nuts.. boost seems to work and pull fine prior to hitting those higher revs, like the additional pressure is causing a leak???
https://www.sau.com.au/forums/topic/188252-losing-boost-after-4500-rpm/
When I removed my plenum to inlet manifold gasket I noticed it had been leaking.
When refitting inlet manifold/plenum/throttle body gaskets I gave them a spray with Hylomar just incase.
Using Hylomar also helps should you have to pull it apart again; it prevents gaskets ripping etc so you can save a few $$ and reuse. :(
could you haer a sucking sound coming from the plenum when it was leaking.
I can hear a sucking or hissing type sound coming from my plenum at the moment. Didn't know what it was though, just thought it may have been normal. Guess my plenum is leaking then?
Edited by Simmo1985
Would a leaking plenum cause any other problems? Just trying to figure out if that is in fact the problem, because the car drives perfectly normal otherwise.
Edited by Simmo1985
No strange sucking noises apart from the usual idle sssshhh noise :)
I think mine was only leaking on boost as it didn't cause any strange idle issues or afm readings.
i got this same problem, i hear a loud hissing like noise come from the plenum at high boost and notice my PSI drop from 20 to 15.. I still haven't got around to pulling the plenum apart and changing the gasket, but i'm pretty sure thats the problem..
  • 3 months later...
I think I have a similar problem. Had it tuned running 18psi no worries but after a week of driving it doesn't seem to hold boost. After 6000rpm the boost drops from 18psi to about 5psi. I can't hear any strange noises though..
I dont think its the inlet sucking closed as I placed a metal pipe in part of it. It looks a little weepy round the plenum gasket. Hopefully thats it..
ANYone got the part no. for R33gtst?
Edited by benl1981
The mechanic reckons I should just change the gasket without even running it on the dyno. They reckon theyve seen a lot of this on the rb25s. It isn't always that easy to hear apparently - and under load there is so much air floating around there with the fan going etc..
Will have a bit more of a check myself..
Nissan want $85 for one! There was a little oil residue around the join. We cleaned this off but there isn't really much coming back. Might run it up onto boost a few times and check again. I did a few 0-100km/h runs the other day which may have blown it apart..
Edited by benl1981
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
