Gday jash, im in tokyo so itd be great to tip a few with you when youre in town. Dont know if youd want to socialize with an undesirable lout like me though...!
ill be heading to TMS myself as i want to see them unwrap the GTR with my own eyes but also to have a gawk at all the other forms of eye candy they have there... :):D:rofl:
https://www.sau.com.au/forums/topic/188271-jash-in-j-07/#findComment-3397285
how do you find the ibis in roppongi jeff? I have previously used my friends appartment down the road whilst he was over seas, but if I can't next time i'm in town I was thinking of giving the ibis a shot.
https://www.sau.com.au/forums/topic/188271-jash-in-j-07/#findComment-3407665
Who is kicking around in J at the moment. Will be there till the 29th. Would love to see any of you that are there. Will you be around Rezz?
Jash
Unfortunately I won't be bumping into you in a Chiba backstreet again while your there Jash, I will be there in January though.
https://www.sau.com.au/forums/topic/188271-jash-in-j-07/#findComment-3407691
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
