  • Replies 50
If my HKS Super Dragger came ith one, I dont think they are that bad (and mine is NOT a straight through resonaor)
yer.. its got that bulge doova.. now at least i know what it was.. the exhaust place where i took mine to be noise tested last week checked it thru, goes, "yup, yup, yup, you got one of those, those and those", "thats what you need for it to meet the requirements", but i neglected to actually ask him what the bulge was.
You also are not allowed any artificial restricters in there and the only legal silencers are those that are welded in. Some people know that, but for those that don't, dem the rules.
3" dump, highflow cat, HKS Super Dragger II combo is right on legal, measured just at 90db @ 5200rpm. With the stock airbox on it will be under. I don't even have to remove mine for the EPA test. Its a good exhaust combination if anybody looking for a nice legal exhaust with heaps of flow.
And you can fit kittens in the back end if you like as well :)
what u talkin about? u must be thinking of the post i made in the "will these rims fit" thread
me?
me?
bsa 180s look better powder coat them in gold
are you sure you didnt post something in here before about those wheels??
um well, i guess i can explain :alcoholic:
but i thought that is the 2nd muffler?? not a resonator?
meh i'll check the rest of the pipes for one of those small doovas... cause i want to get rid of the big ugly black boxy thing.
If it is a resonator im leavin it in
from the engine it goes cat, resonator, muffler.
they all have different sizes and shapes between factory, and high flow.
the bigger the volume inside the resonator/muffler the quiter it is.
3 options: normal "oval" shape and straight through.
normal will have the in and out pipes not lined up, this is the quitest but least flowing. or they will line up but will be detoured inside the muffler.
straight has the pipes lines up for increased flow and performance and also smaller volumes for louder sound and i assume increased performance.
just take it out and see what it sounds like.
ive been looking for an exhaust for a while and i went and listened to one that had no resonator. it was still farken quite though cause he had std turbo and dump and 2.5 cat, plus the volume of the muffler was quite big. do if your car matches this description, or is close then it should be alright. but just give it a go and see what happens.
inark the cheapest way to do it is get under the car with a tape measure,and measure it between the welds of the resonator,but add about an extra 40mm either side,then goto your local exaust shop get a piece that length in 3" pipeing and get them to flare it out both ends to fit OVER 3" pipeing then take off your exaust at home cut the resonator off then put that peice in and weld it up :D
and thats how u do it for free (thats if the exaust place isnt a tightass and gives u that little peice for free)
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
