if you want something else we have a nice car that you would love at work :)
a Hyundai Tiburon - standard engine/exhaust/suspension with a big drift style spoiler, 19"s and orange tint
some Korean Rice to go........
i had to laugh when i saw it
I done some ringing around and found out that emmistion testing is 700dollers a pop at regency. You can engineer coilovers but they must have 2,3/4 travel so that puts a lot of brands out, bigger rims can be done but must have tyre size chart sticker on the car(cost more)
After talking to a few Engineers i found out that Emissions testing in adelaide is still going thro some loops but will be sorted out soon
So i recon im going to machine the rb30 of the block lol and change to a stock plenum put the power fc in a stock ecu shell for now
Thats excellent.. I too was told petrol emissions testing is currently in the air as a test standard hasn't been decided upon yet and this was a good 2years ago. I find it very poor that they haven't decided upon such a simple emissions test cycle. :D
I believe they must have something sorted as a few have stated on other forums they have had emissions testing done and its been all good. 'Apparently' Who really knows. :)
Dan, Congrates buddy. All the best in your future fast endeavours.
Never know; u might get bored of the EVO in a couple of years to come and find your way back in to a GTR making some real power. None of this sub 300rwkw crap. :)
yeh getting a motorbike and the evo most likely hardest part is whether to find one in japan or buy here in aus
get one of the evo wagons not very common over here. only 150-200 made. It would give a few people at the lights a scare or 2
http://www.prestigemotorsport.com.au/deale...php?carID=29667
Edited by Whiplash
Omg i think im going to explode..... I just ate a 536gm Tbone, 2 big bits of corn and 6 hash browns.....I took a photo, it was that good, but i had to put the hash browns on a seperate plate as they wouldnt fit on my biggest dinner plate with the steak and corn....
I've planted a shiet load of water melon seeds.
3months time I'll have so many water melons I won't know what to do with them. Fingers crossed anyway. First time at myself being a green thumb.
Might try growing some square water melons too. :)
w00ties
i have hydro..........handbrake
need to get one last bit to finish it and i'll try it out...............in my driveway :)
shaun did an awesome job for me - but as for his recommended towie..........well, thats left to be desired
Need to get my licence so just a cbr 250 or something similar to start, ridden motorcross bikes and mates roadbikes gsxr 750 and 1000's (shhh dont tell the popo) since i was 4, so figured I should actually get my licence finally so then i can get an R1
youve riden a GSXR since you were 4 my goodness man why arnt you valentino rossi :)
Luke - Chris get you the pads i take it and how much over $100 is pricey assuming it was over 100
I am valentino rossi man.....but only on the weekends....
Hahaha very funny steve such a comedian :thumbsup:
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
