me + mo-vember = undercover cop in a skyline ?
im going against the flow, most guys i know trying to flex out a mo are going for the chopper style, im gonna start on the tom selick/dr. phil mo, then move on to a more tailored jack white affair :P
fact is i look like a fool :thumbsup:
i hate the halfway mo.
when its half there, but half not, and looks like a school boys best attempt at becoming a man.
hahaha yeah, luckily enuff im past the 1/2 way mo... it was tuff... had to stay inside for a couple days :thumbsup:
found my self the ultimate import ;) 900hp + 1000Kg = F*&^ing AWESOME
http://www.closeratio.com/asp/default.asp?...ils&id=1006
$274k?
ill take 2.
ill grab one of these too.
http://www.closeratio.com/asp/default.asp?...ils&id=1649
nobody has an excuse for not spotting me anymore LOL
PK will vouch for me having bought SAU stickers................and its going to become Sinista's worst nightmare.................theres 3 SAU stickers on my ute now :D
