just thought id ask a random meaningless question here.
how come SA never posts in the events section? all the skyline cruizes seem to go in the regular section which is fine n dandy but why have the extra section at all only outsiders seem to post in there.
i come on this page before i got my skyline like 2-3 years ago went straight to the events section and seen the last event was like 6months prior to that date and I thought the club wasnt running anymore.
I think its because majority of the readers on here only look in the General section and forget about events.
I think when SAU/SA gets up and running, it would probably get used more if there is a regular calendar of events coming up - then there can be threads for the upcoming events.
Wish me luck guys as im off to fiji with the missus to tie the knot fiji style and then honeymooning on a secluded island :huh:
Oh wow how cool :)
Best of luck!!!
...but I've got a headache :yes:
haha it actually cures headaches :)
