just thought id ask a random meaningless question here.
how come SA never posts in the events section? all the skyline cruizes seem to go in the regular section which is fine n dandy but why have the extra section at all only outsiders seem to post in there.
i come on this page before i got my skyline like 2-3 years ago went straight to the events section and seen the last event was like 6months prior to that date and I thought the club wasnt running anymore.
I think its because majority of the readers on here only look in the General section and forget about events.
I think when SAU/SA gets up and running, it would probably get used more if there is a regular calendar of events coming up - then there can be threads for the upcoming events.
Wish me luck guys as im off to fiji with the missus to tie the knot fiji style and then honeymooning on a secluded island :huh:
Oh wow how cool :)
Best of luck!!!
...but I've got a headache :yes:
haha it actually cures headaches :)
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
