its ben spec now...........he sent me a photo and told me i had to witness it in person..............physically wouldnt be able to get it lower LOL
LIES! :D
I heard that it's going lower now..... :banana::w00t:
Oh, heard it runs too. >_<
What radiator is better for a r31 with a rb20det a 50mm Alloy Radiator or a r31 rb30e radiator?
S3 RB30E radiator is the best. Even against a 50mm alloy.
Joel (SLY-031) hasnt seen over 80 odd degree's in his, and that isnt just some hard driving. Thats straight out thrashing.
Id tell you how good mine is, but my car hasnt been driven in 8 months or so >_<
Edited by R31 drift pig
most of your block heard that it runs :D
They're gonna figure out that it drives as well :D
Just need those caliper banjo bolts machined and extended wheel studs for the front.
Soon my pet.... soon :D
haha, fair enough.
you said it yourself, it aint worth it, but its still gonna be a shitload of fun :D
especially on private property and shit... :D
Edited by scandyflick
Id tell you how good mine is, but my car hasnt been driven in 8 months or so :(
+1
i dont hav any problems with coolant temp with my stock radiator
only thing that causes a temp issue with mine is lack of oil cooler
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
