on another note
hey ryan.........goin to take me up on that offer for ya wheels now? they are second hand afta that job u did of munting the lip
$50 offer still stands
luv u long time LOL
btw, james also says he owes ya a 6 pack too hahahahaha
I was wondering what you meant by red/clear - The indicator sections are clear. Look pretty good. Found any springs yet? If your not aware of it, have a look at www.fordforums.com.au - Good resource for all things ford.
Alternatively, you should be able to get a set of springs from any ford wreckers pretty easily, tried Athol Park Ford Wreckers?
Im going to look this weekend for a new set of springs but now that iv got ba xr8 18inch mags on order(2 weeks wait) im not sure what to get 2inch or 1.5?
i hate my car right now................ she had a knock reading of 160 the other night :D
but i will be ordering my new genuine east bear eyelids next month.................mmmm east bear hotness cant wait :thumbsup:
Edited by MissR34
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
