finance has been approved for the person buying my celsior today.
couple days time, ill be one celsior short, minus a bank loan, and ill have a $5k heavier wallet...
... nice.
Edited by scandyflick
^^ Ohhhh were all gettin new cars hey!! Last night i ordered my 19s, today i got Ryan to get me some Coilovers, and im about to book into Auto Perfection for some nice tint and alarm!!
So Skandy what are you gonna be getting now then??
Lee whens your beast land on a dock near you??
Well the legnum was in Brisbane on March 2 - but only got cleared from Customs on March 20! Rang Toll yesterday (doing transport from Bris-Adel) And the car should be at the depot on Monday March 31. Then off to Premium Motor Co for compliance, so expecting to be on road HOPEFULY by Friday April 18.
In the mean time my parents are off to NZ for 2 weeks, so i'll have Dad's 275rwkw XR6-T to drive for a couple of weeks, from April 6 :ermm: So next week should be the only week my wife and I will be down to 1 car.
My mate owns a 309.9rwkw xr6-t ute. Youve probably seen it around. It's red with the numberplates SLOW. Driven it a heap of times including back from melbourne....To be honest id rather drive my 33.
^Don't get me wrong, I certainly wouldn't prefer the XR6T over my legnum, skyline etc. BUT it sure makes a nice daily for a few weeks rather than my sisters old clapped out VT Commodore V6 which was my other offer for a car LOL
dunno, been flirting with the idea of a modded s13 or an ST165 celica GT4, but a few things are changing in regard my living situation, so i know id be better off saving my money... probably means no car for 6 months or so, and the celsior was the only thing keeping me sane, should make for an interesting couple months.
yay, receive final payment on my ute lid tonite.........take it to get taken off tomorrow
securing final details for a canopy :D wagon styles. its going to need a rattle can job (from white to red) but im going to have a shit tin more storage space (its a high roof version, highest point is about 800mm above the edge of the tray :D)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
