does any1 know how much (roughly) a set of Apexi (not sure of exact model) coillovers should cost second hand. Everything adjustable and are fairly new ???
well i wouldn't pay for than 1k!
i think you can get the n1 exv ones for like 1.5k?
Edited by nos man
they make coilovers
and for what car
Yeh. S13 ones in particular. sorry should have specified.
saw sum 4 900, might be able to get them cheaper.
around $400-$700 per axle, dependent on condition.
K. thx.
Thinking of puting these in my 31 and giving drifitng a go since i have never done or tried it before...
What spring rate are they? Too soft and it'll be poo....
What engine are you using etc?
And just double checking, you do know you'll need an S13 front end and drill the rear towers or mod stock tops/get cusco pillowball HR31 rear hats for them?
ok well i was going to get drty2 but i didnt due to disagreements
thanx for the help guyz well sort of..
and im 16 and well yey learning to drive but ive nearly done 50 hours and every assessment i got given a 100% pass
and i love imports
but free car who wouldnt take it????/
i picked up a poineer head unit 2x 4' splits and 2x 6' splits for $228 Woot!!!!!!
Edited by Pepsinator
So because you've done *gasp* nearly 50 hours of driving, you are a hero and can do fully hektik doughys and just be fully sik in general? Please!
I'm sorry if I'm coming across an ass here but the last few months there are certain members that have joined this board that are bringing down the general quality of this forum and I feel ashamed and embarrassed that they are associated or have anything to do with SAU. I dunno if other people feel the same but I'm already enough of a target as it is driving my car. I don't need the police reading these forums, seeing reports of "doughies, spinoffs on the free way, etc" and then seeing me drive down the street with an SAU sticker on my car and associate me with that behavior. Yeah, you are 16, fantastic, I was once that age too, never did I resort to such foolish behavior and while I'm no angel, yes I do speed, we all do and yes I haven't done things I'm proud of, I'd like to think I drive without putting others lives in danger and on the odd occasion I have done something stupid I haven't come onto a public forum to brag about it to try to boost my ego. Fact is, it doesn't impress me and I'm sure it doesn't impress 99% of the people on here. I have a friend who drives like a dickhead and his behavior doesn't impress me either, don't think I'm having a go at you because I don't know you, I just don't want to see this club go to shit and get a bad rep like so many of the others out there.
Mods feel free to delete this post if you feel it is out of line but I'm just expressing my feelings and is not a direct attack on Pepsinator, I'm sure he's a good bloke, I just don't think he fully understands the shit that can go wrong behind the wheel and the consequences thereafter...
Unfortunately I don't have such a luxury... yes I drive what most would be considered "cop-bait" and that is my choice. However, childish and reckless behavior that brings all Skyline drivers into suspicion under the eyes of the law just makes it 100x harder to just enjoy my car for what it is without being harassed from SAPOL
so true man cant say much more than that hate the look i get from cops when im driving fine and the old get up ur arse then back off and back up again drives me nuts all because of other peoples actions
+1 i agree with u luke not to harsh at all hey glen did u get that price on the blasting yet
Nah still havn't been in yet, had a few distractions last week will try go in and see the mob during the week, will let you know mate.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
