044 Intank is quite easy.
R32:
044 from Motor Tranders for $260 (mentioned I can purchase one from SAU for $250 ish delivered so they did their best to price match)
2 brass barbs and some suitable fuel hose from Pirtek.
Have the pickup brass barb machined on a lathe (boostworx did mine) so you can use the standard sock.
2 large hose clamps
Put it together dropped in tank easy as. :)
Its a fair bit harder to fit in the R32 as there's not much height available in the tank and requires machining of the pickup barb. The 33's are dead easy to fit the 044 pumps intank.
The pump has a nice buzz to it; as loud as my old VS 5ltrs pump. BUT when the weather warms the pump gets a little loud from outside; inside its still fine.
i wouldn't say dead easy on a 33, intank was a pain in the bum, if you want to get a decent amount of fuel out of the bottom of the tank its a pain in the arse. Because the pump is a larger diametre and the bottom of the tank closes up towards the bottom it can prove a pain in the arse getting the rod and to clip in the bracket, not cutting your arms up at the same time can be hard.
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
