lso just saw on the news flash..
police disturbed a hoon car club! oh wat do u know.. holdens and fords!! not skylines!!
maybe they will open thier eyes!!
lol
i thought RCK was back again when i seen that
open their eyes and see that douchebags drive skylines aswell?
think about it, it isnt only people in commodores that drop skids, import drivers arent innocent.
Yeh i've done a few in my car, but hey, GTR's cant do burnouts :banana: (its not reconmended, i need a new rear tyre because of it :ninja: )
Yeh i thought RCK were known as 'the hoon club'. And they are still around, just keep their cruises and website hidden :thumbsup:
Its always the Commonwhore fools that are the biggest problem.
Everytime when I go 'riding with the boys', its the wankers in their commonwhores who want to race.
My bro hangs out with a few of the club members and I can tell you first hand they are wankers and trouble makers.
And my GF bro goes on street machine cruises (he's got an awesome 350 chev powered street machine), and I've tagged along and seen the commonwhore idiots crash their party and drive like dicks and attract the cops.
I have no patience for commonwhore drivers ... can you tell? :thumbsup:
hides in corner from ruby
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
