If someone wants 250kw's and killer response on a 25, I have a Trust TD06 17c 8cm kit for sale.....
Looking at getting a HKS2530 kit Ive found.....
Have also seen that the GT2871 is an awesome turbo on a RB25..... Ryan's 33 is making great power for the little boost is's running and stupid response.....
Edited by R31 drift pig
yeh i sorta looking at a turbo which will give me the same power + response of my apexi ax53b70 p25 but i want to keep my engine LOOKING stock!!!
hence y i was thinking r33 hiflow... i herd these can make very good power! and i just want those snooping eyes to not see any different!
would this be a good way to go?
well i just broke my GTR plastic front bar! :D Caught it on the gutter that was just that bit to tall when it dropped off. Just on one mounting point thankfully-it also broke my indicator aswell tho! I still need to get it painted, but does anyone know anyplace which can make a R32GTR front bar fit a gtst, and fix this mounting point? Any help appreciated!
thats for god dam sure ben
250rwkw on 14psi with 14psi at 2200rpm, pulls like a freight train and hits the mid range torque and wheel spins like a mofo in 2nd, Had 100% full intentions for a gt3540 but have now decided to keep the cash. couldn't be happier.
but yea that td06 17c would be an excellent turbo too.
My TD06 is the internal gated version... and comes with a alloy bracket which you bolt the stock heatshield to...... so certainly can look like a stocker.
theres no massive trust logo's or anything on the front cover etc....
trade ya for the apexi turbo.........
I spoke to Bill Keen before I left for perth about making me a custom turbo using my RB25 turbo housings and machining in a GT2860 or GT2871, and he wanted $1750 I think.......
Did you get your retune ryan? so you cracked 250 then? Awesometown. :D:huh:
just turned up the boost 3 more psi and took the tinniest amount of fuel out, still rich as balls, you can tell by my rear bumper which madaz seen the other day lol.
ben, that's what i got champ, the rb25 rear, gt2871r front cover, fair amount of machining in the rear.
just incase people are interested we made a screamer/dump 3.5inch full system yesterday for my mate's xr6t ute and gained 30rwkw. went from 304 to 334rwkw...its such an insane car....screamer on the 4 litre sounds insane.
Edited by Ryanrb25
yeah.... But Bill was talking about using the RB25 front cover too, so for all the world it looks like an OEM nissan turbo.
Cant really justify spending it when I have the TD06 sitting here. Unless someone wants to buy it LOL
yeah.... I guess you can call it that.... reckons the GT2860 in the 25 housings is a great little unit, tops out about 220odd on a 20DET.
Keen on using the td06, but a bit apprehensive about it's lag tendencies...... and because its a rare model, no-one seems to really know what it's capable of...
General consensus seems to be full boost around 3500-3700, (depending on who I speak to) max out about 220-230kw's....... capable of 250 - 260 on a 25DET
Been said it's a little laggy, but she's pulling like a freight train @4K or so.
If I dont get any interest Ill chuck it on and see what she's like...... maybe Ill invest in some cam gears and see if I can bring it on a bit quicker/harder.....
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
