bah. as if my partner wins something at Kadina Show and Shine and i dont hahahaha.
well done tho on winning Best 4 Cylinder with the WRX, Lex im proud of ya for winning your first trophy. :ninja:
just remember i have 10. YOU have 1.
:blink:
well just got my car back from jeff...
pulled 189.9rwkw on 14psi....
afm meter was maxing out?????? green label?
ok i have a gtr power fc modded for gtst.. now jeff thinks coz the gtr runs 2 afm this may be the reason mine is maxing out?? would this be the case?
coz i thought i would hit atleast 200 with my setup?
also my clutch is sooooooo hard to drive with! stalled it 8 times on way home!!
oh i wanna cry!
The RB26 AFM's are rated less than the 25's I know that for certain, this is probably your issue... question though, is you AFM an RB26 one or 25? If you are using a modded 26 PFC with a 25AFM you shouldn't be having any problems
EDIT: Just saw you have a 32, no idea where the RB20 AFM's fall in the scheme of things, would think the 26 has a greater reading range however
Edited by heslo
STEVE!!! its not funny! im about to throw something!
thats wat i thought! well im gonna ditch my pfc and get a remap! i think the PFC is holding me back??? joel i know u wanna help hahaha
oh spewing so bad! and my clutch made it worse hahaha
damn wed!
jeff said he thinks the green label is having trouble working with the gtr pfc due to a rb26 running two afm! he said i should get a z32 and i agree but im just trying to c y i would be maxing out at 190???
isnt that strange??
and yes i will toughen up hahaha its wat happens when u have a slipping clutch for 6months and get used to being able to ride it hahah
isnt that strange??
I would assume the green one is a RB20 AFM??
I can understand why the 26 PFC would need 2 AFM readings as its twin turbs, but i dont see any reason why they cant wire it up to 1 AFM and have the same reading for both on the PFC, Im no mechanic or auto elec........
hahaha i lol'ed
give it 2 days of driving with new clutch and you wont look back
GTR afms are brown but i think there pretty much the same as the green ones just different wiring
go here for a nights worth of READING
of Luke of you do think of getting the R34 MFD this will be handy for you >>HERE<<
here is a AFM chart too :merli:>>Here<<
:blink: In other words... toughen up princess, right Steve? :ninja:
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
