^^ really? will it stick??? was looking for the dacals that stick on the cap themselvs but could only dind transformer prints in black, not thanks! lol
i need some brake paint to, so ill have a look......has any one else painted centre caps?
Edited by craig R33
yeah currently 4000kms into the current Motul turbolite 8100 10/40w
got 2 for one a year ago.
hhhhhm not sure, might just let the tuner take his pick :D
Motul ftw. used to run it in the silvia for ages. Not sure what my mechanic uses on my line, Mobil 1 im pretty sure.
what should I use
have 5L of both Castrol Edge 0/40 and Motul turbolite 10/40
Pffff when the oil is only in there for 5k kms it prob wouldn't matter too much, they are both a similar grade anyways!!
Castrol are also a decent "brand name" so whatever really!!
Your engine wont go bang because it has Castrol in it as aposed to Motul, But it will go bang if you take too long to choose and you run out of oil!!
Edited by Deluxe
^^ Would if i didnt have a work promo night tonite at the convention centre - 3 course meal and all you can drink, alcohol + softdrink. + entertainment (last year was that cirque de solai thingo) + lots of prizes. Wooh!
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
